New Product from TMS - E46 Rear Subframe Reinforcement Kit - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 01-17-2005, 10:16 AM
TurnerMS's Avatar
TurnerMS TurnerMS is offline
Mein Auto: '02 BMW R1150GS
This product is now finished and in stock.
http://www.turnermotorsport.com/html..._ID=TDR4675412
Doug
TMS
Old 01-17-2005, 11:57 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Doug
TMS
Doug,
Have you seen any of the Z-series cars failure modes?
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 01-17-2005, 12:01 PM
TurnerMS's Avatar
Originally Posted by JonM
Doug,
We have not seen any Z3's in our shop with that issue. With the E30 style rear suspension, we have seen some diff mount failures, that is about it.
Doug
Old 01-17-2005, 12:13 PM
Andre Yew Andre Yew is offline
Mein Auto: 2000 E46 328Ci Bright Red
The kit looks very nice! FWIW, when my rear subframe tear was repaired, reinforcement was added to the area. It seemed to be part of the normal repair process for the E46.
--Andre
Old 01-17-2005, 01:25 PM
TurnerMS's Avatar
Originally Posted by rumratt
Doug, do you guys have a pre-canned price for installing them? Or is it based on an hourly rate (with 8-10 hours estimated)?
It's based on how long it takes us, which is based on the individual's car. We do not charge flat rate labor.
Doug
Old 01-17-2005, 07:33 PM
bluetree211's Avatar
bluetree211 bluetree211 is offline
Send a message via AIM to bluetree211
Mein Auto: Z4MC
Doug
Would you do a canned price for a car that has no damage, ie preventative install? Seems like you could accurately estimate that pretty easily, since you dont need to do any repair work, and all cars disassemble and reassemble the same way. I think we just want a ballpark to figure out if we should come play...
Old 01-17-2005, 10:23 AM
Gabe's Avatar
Gabe Gabe is offline
Mein Auto: '05 330i ZHP
If I were buying and not leasing I would definitely pick this up.
Seems like a great price, assuming it does what it is supposed to.
Old 01-17-2005, 10:42 AM
Gabe's Avatar
I am no welder either, but I have friends who are quite handy.
Old 01-17-2005, 11:06 AM
Elwood's Avatar
Elwood Elwood is offline
2 pieces dry white toast
Send a message via ICQ to Elwood
Mein Auto: Mystic '04 330ci
If it were just a matter of buying the kit, the price is peanuts. It's getting it installed that is the PITA.
Welding is not one of my areas of expertise.
That's a ton of work.
- 2004 BMW 330Ci - Mystic Blue - Sports Pkg - Hole in Roof -
- Bum Warmers - M3 Wheel - ZHP Knob - Arai for the noggin -
- UUC Swaybarbarians - To tell me this is a repost, get in line -
Old 01-17-2005, 11:49 AM
TurnerMS's Avatar
Yes, a considerable amount of labor. Typically 8-10 hours depending on damage. The alternative you ask? Replace the entire rear floorpan with a factory body panel, pay a body shop to rip out the entire rear of the floor and replace with new and then paint it. That is at least double the time, not to mention the price of the parts from BMW. If you do that, we still recommend you install this kit to prevent it from happening again.
We weighed the options for a while and we have found that this is the right way to fix it. We have seen a lot of these cars lately with subframe mounting completely ripped out. The car we used for the photos for example, it was a customer's car, 100% street driven, 100,000 miles, the car never saw one day on the track. We have used this kit on a half dozen cars so far.
The lowest mileage car we have seen with this issue had 60,000 miles. However, we have seen some E46's with 200,000 miles on them with zero issues.
Doug
(Edited for spelling)
Old 01-17-2005, 11:58 AM
HW's Avatar
HW HW is offline
lurking
Mein Auto: 323ci, manual
any possibility in making a trunk only reinforcement kit for cars that have no damage.
2010 Acura TSX manual
Elwood's Avatar
Doug
Definetly sounds like the right way to do it. I'd love to have it done to mine . Maybe if I'm ever up your way..............
Old 01-17-2005, 06:50 PM
LarryN LarryN is offline
Mein Auto: '16 F82 M4, '97 332ti
Hi Doug,
That looks like quite lot of good research went into that kit. Did you happen to do another car recently? My buddy had his done this past week, and I thought that was his car in the pics. He's done lots of driving schools, track days, and 3 seasons of autocross, and only has 68k miles. Is it another 2001 Orient Blue 325i E46 that you did for those pics? Also, I don't believe he had any problems with his rear subframe mounts before. Was the first pic in the instructions from the same car, or a file photo. I'm curious because he does a fair amount of driving events, as I do, and I want to keep an eye on things on my car.
Thanks!
Larry
Old 01-18-2005, 07:17 PM
I just noticed this. My rear subframe tore out at 41K miles on a stock suspension car.
--Andre
TurnerMS's Avatar
Any word on the rumors that the tearing is caused mostly due to a bad batch of sheet metal? There have been almost no reported cases on 2002+ vehicles (or is it 2001+). Of course, they are newer, so they've had less time to wear out.
Based on our customer data, this is accurate. The six cars we have done in house have been 98, 99 and 2000 production.
-D
TurnerMS's Avatar
We also had one 2001 325i.
Doug
Old 01-22-2005, 01:03 PM
dynosor's Avatar
dynosor dynosor is offline
Mein Auto: 2003 E46 330i
Any chance that's why we have the CDV?
I wonder if BMW started using the CDV (clutch delay valve) to cushon clutch engagement to reduce drivetrain shock and subframe fatigue... Anybody know when the CDV became standard?
I generally don't do hard launches in first and tend to floor it from second gear for the sake of smoothness. I am sure this is much easier on all the drivetrain mounting points.
Old 01-22-2005, 09:06 PM
sp330i's Avatar
sp330i sp330i is offline
Be a race car Daddy!
Send a message via AIM to sp330i
Mein Auto: '01 330i SP, PP
For those of you that may not be following this other post, look here. http://forum.e46fanatics.com/showthr...hreadid=195602
While most failures are reported on MY 2000 and prior, there are several that are 2001 and above. I'm curious if it is more a function of mileage and not necessarily related to MY. Most MY 2001 and later 3s may not have have enough miles on them to experience the failure.
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 12:44 AM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
The $95k E46 M3 BlackChrome General Automotive Forum 19 06-01-2006 05:32 PM
Can anyone verify if these Bluetooth Retrofit Kit Part numbers are available? m3evolution General BMW Questions 25 06-22-2005 08:21 PM
Is Lemförder (the owl) the OEM Control arms supplier? Fifty_Cent 3 Series & 4 Series 1 09-18-2004 07:56 AM
