E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Windscreen washer not working!
One of the windscreen washers has stopped working. The passenger side is fine so I am assuming that the pump and the pipes are okay.
Can I do anything or is it just a matter of replacing the nozzle? |
could be frozen or clogged
2012 135 Coupe Alpine/Black; M Sport, Premium 2, 7 sp/dual clutch, HK, Sirius, Apps, Nav, Heated Seats |
It couldn't be frozen its not cold enough but it could be clogged. Is it possible to remove it and blow it out?
I think the nozzle is a heated one, does that make any difference? |
The fluid is probably frozen. Give it a few days to sort itself out. I've had it freeze before when I too thought it wasn't cold enough.
I'd say frozen fluid resevoir or lines. They don't thaw out nearly as quickly as you would expect/want.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Heated Washer Nozzels not working | NH-SHICKS | 3 Series / 4 Series | 0 | 12-20-2004 07:45 AM |
| Any appliance gurus out there? Washer issues... | Jetfire | Off-Topic | 22 | 01-03-2004 01:26 PM |
| Headlight washer seems to be leaking... | pmb1010 | 3 Series / 4 Series | 2 | 04-20-2003 08:46 AM |
| No luck with leaking washer fluid | Sjumper | 3 Series / 4 Series | 6 | 01-24-2003 09:22 AM |
