E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Just yesterday, I got in my 93 318i, and when I started it up, the Service Interval Light area was all dim, and after the engine started, my Brake Fluid light and Park Brake light remained lit. I drove it around the parking lot, and noticed that my Tach as well as my temp gauge and fuel gauge were not responding. I tried restarting the car a few times, but no joy. Here is what I've checked so far:
Fuses under hood, all looked good and lit the light on my fuse tester. Tried disconnecting battery for 10 min and reconnecting, tried using my Peake tool to check for fault codes (none, as expected, since no CE light came on) and checked brake fluid level (at max line) and park brake functionality (worked). I can barely read the dim odometer which does still function, which is how I'm going to have to tell when I need fuel. Does anyone else have any ideas for me to try? I think I'm going to start replacing fuses next. . . Thanks for any help! -drew- |
did you check your battery, I know it seems kind of stupid but have it checked. how often do you drive your car? check relays.
I had to replace the gauge cluster on my '94 318 because the entire cluster would start/stop working intermittently while driving.
Faulty clusters are a fairly common problem with the early E36's. My replacement cluster was cheap - the reprogramming of it wasn't. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Help: My Fan and A/C Completely stopped working | palooka666 | 3 Series / 4 Series | 4 | 06-26-2004 08:34 AM |
| Replacement Gauges on 325ci???? | bsirk | 3 Series / 4 Series | 0 | 04-06-2004 10:04 PM |
| None of my gauges are working, and my car is hissing at me | Citygal | 3 Series / 4 Series | 7 | 09-16-2003 07:58 AM |
| Gauges quit working (86 325ES) | den | 3 Series / 4 Series | 0 | 06-07-2003 04:48 PM |
| Tire Pressure Gauges - Article by consumer reports. | JSJAMALA | 3 Series / 4 Series | 0 | 07-20-2002 11:24 PM |
