E30 (1982 - 1993)
Old 03-05-2005, 12:41 PM
rgouette rgouette is offline
Mein Auto: 1987 325
"Fixed" my idling problem: 1987 325
Just bought the car, & it had that notorious surging/revving problem where after reaching operating temperature, the engine would rev between around 900 & 1500 RPM.
I bravely(perhaps foolishly) decided to try adjusting the Idle Air Stabalizer Valve screw (remembering where & how much I was turning) & I found that with 2 turnsclockwise(into the body of the valve) the engine is now settled around 900 RPM.
Much better I think than that other buisines!
I hope it stays!
Cheers!
Rich
Old 03-07-2005, 07:09 AM
Mein Auto: 1987 325
hmmm, welll maybe not exactly 'fixed'....
I hope it stays!
Cheers!
Rich
This morning it seems to still surge, but not quite so bad.
Guess I'll be digging in more. ECU?
I haven't changed basic stuff yet, like plugs, cap, & even the air filter so guess I'll
hold offf on positive results till I change that stuff.
Rich
Old 03-07-2005, 08:46 AM
pup's Avatar
pup pup is offline
Mein Auto: 89/94 325is 02 325i 05mcs
see if this link helps:
http://www.mesaperformance.com/faqs/idle.html
Old 03-07-2005, 07:54 PM
Mein Auto: 1987 325
Excellent!
Hey, thanks man. Did a quick readthrough, & will try some of the big wisdom contained therin..
cheers!!
Rich from Maine
Old 03-26-2005, 09:19 PM
Nowak Nowak is offline
Mein Auto: 1988 E30 325e
Originally Posted by pup
That has to be one of the best write ups I've ever seen. I've had an idle problem for a couple of years now and I hope I can find my reason in here. Is there anyway that the ICV or ICM could cause a missfire at idle. My car runs fine when moving, just a bad missfire when I stop.
Old 04-08-2005, 10:16 AM
9x16's Avatar
9x16 9x16 is offline
Mein Auto: 89 BMW 325i (4 door)
Wink
I had that problem on my previous 325e.I replaced the o2 sensor,and the problem was gone.If your car has rough idling,hesitating,other related problem.Then its more than likely the 02 sensor in your exhaust.
Old 04-08-2005, 06:50 PM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
idle stuff
buy a haynes or bentley repair manual (20-40 bucks) and get out your voltometer and check the ohm's and voltage resistance in these things throttle position switch ,air flow meter,and then check your feul pressure and your fuel pressure regulator . Oh and try running your car at night looking at the plug wires this way you can see if a wire is grounding to the motor and some bosch plat +4's would be nice, i havn't found an rough idle yet that a $6.99 spark plug couldn't fix.good luck
p.s.if all else fails check compression
Similar Threads
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 07:38 PM
325 Ci Cabrio Roof problem berlinerb 3 Series & 4 Series 3 10-21-2003 06:59 AM
t Nick T. The Test Board 5 07-05-2003 10:25 AM
'03 325 Fuel problem PropellerHead 3 Series & 4 Series 1 03-19-2003 01:11 PM
jon...need help...big problem (m) bimmerboy Regional Forums 6 10-28-2002 07:17 PM
