The X5 SAV Forum
Old 03-12-2005, 12:36 PM
Zeke013's Avatar
Zeke013 Zeke013 is offline
Mein Auto: 4.8is
How do I locate my Bluetooth Passkey?
I got no documentation of Bluetooth in my 2005 X5. But I know it's there after I do the set-up as my phone locates it. But my phone also asks for the Bluetooth Passkey prior to allowing me to link it to the vehicle. But I can't locate this passkey anywhere in/on my vehicle. Anyone here found the passkey code on their vehicle somewhere?
Thanks.
2005 BMW X5 4.8is
2005 Audi S4 Avant
Old 03-12-2005, 02:14 PM
King's Avatar
King King is offline
Mein Auto: X5 4.4i
Look for a white sticker on the BT ULF module itself. (In the trunk, driver's side, underneath the black plastic floor/cargo panel.
ID:	46259   Click image for larger version
ID:	46260   Click image for larger version
ID:	46261   Click image for larger version
Old 03-12-2005, 03:46 PM
Zeke013's Avatar
Mein Auto: 4.8is
Awesome!
Thanks!
Old 03-13-2005, 12:26 AM
benathon benathon is offline
Mein Auto: 2004 X5 3.0i
I have the passkey card in my owners manual but I don't know how to check if I have bluetooth or not. I have a sony k700i phone and I don't have nav.
Old 03-13-2005, 11:13 AM
King's Avatar
Mein Auto: X5 4.4i
If you have the card with the passkey #, then you most likely have the bluetooth ULF module installed. Your phone should work fine with it although there is no snap in adapter available for it yet.
Old 03-13-2005, 03:34 PM
Do you have any idea on how to check to make it work with my phone?
Old 03-13-2005, 05:28 PM
King's Avatar
Mein Auto: X5 4.4i
Checkout X5world.com under the electronics & cell phone section.
Old 03-14-2005, 04:52 AM
SuperGreg's Avatar
SuperGreg SuperGreg is offline
Member of the club
Mein Auto: 2002 X5 3.0i
Thumbs up Excellent reply
What an incredibly informative and detailed reply. !!!
Remember, "It's a dry heat"
Old 09-03-2005, 10:17 AM
B729 B729 is offline
Mein Auto: 2005 X5 4.4
Bluetooth Pass Key
Just picked up my X5 and there was no card with the passkey. My salesman told me I'd need to come in and have the service dept hook up a laptop and find the code. I looked on this site and found the info posted above and it worked like a charm. The only difference was that my unit was a Motorola and the code was listed like this:
PK: ####
It just isn't spelled out "Blue Tooth Pass Key". Just thought I'd add that and Thanks to the folks that posted previously.
Old 10-07-2007, 12:09 PM
pickers9 pickers9 is offline
Mein Auto: X5
Fantastic post - saved me loads of time chasing car salesmen!!! This really is where the passkey is located - please please please trust this post! Thanks a million!
Old 10-08-2007, 04:50 AM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z4 3.0, 535i
BlueTooth Passkey
If you are buying your BMW used and don't know the history there is one more item that can throw you a curve ball.
In my 2005 X5 we have had to have the TCU replaced for Inop BMW assist. When the TCU is replaced the bluetooth passcode changes. There is suppose to be a new label that comes with the TCU. So, if the tech didn't stick the new label on you will have to have the PK number read or call the selling dealer with the VIN and they should be able to have a record.
(We went through 3 TCU's due to the "red" light on the dash illuminating continuously, BMWAssist Inop. I finally complained about the PK sticker and they placed it on the card in the glove box. All other service times they were placing the new sticker on the service paperwork that remained in their files
Old 12-24-2010, 12:48 PM
rxdesigner rxdesigner is offline
Mein Auto: 540 i
Thanks you very much! I just used this instructions to find the fixed code on my Bluetooth module. It of the type FX ####
Thanks!
Old 08-17-2011, 04:25 PM
etietz etietz is offline
Mein Auto: 330ci
Where's TCU in 2006 330 ci (convertible)
No PK card with my 2006 330ci. Anyone know if the TCU is in the trunk, driver's side, underneath the black plastic floor/cargo panel in the convertible? Hate to tear apart before knowing and not interested in giving dealer $65 to scan!
Old 05-04-2012, 09:25 AM
2hot4u500 2hot4u500 is offline
Mein Auto: 2001 BMW 330ci
I looked in the truck and drivers side, but what do you mean about black plastic floor/cargo panel. I am new to this and just received my first BMW so still figuring things out. Please help!
Old 01-25-2013, 05:41 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
There are pics of this piece and it's location in the SECOND reply in this thread...go back to the beginning of the thread as not to miss what has already be suggested.
BTW...this is an e53 X5 forum...if this is not the type of BMW you own...all of the responses may not apply to your application.
Below is a BMW Bluetooth availability chart:
Q {BMW CCA Member #191509}
(SOLD)
Old 05-04-2016, 07:34 PM
Mumzie68 Mumzie68 is offline
Mein Auto: 2005 BMW x5
Pass key/pin
. Thanks I found and open the back where the bt module is,BUT the sticker is gone. How else can I find the pin without paying the dealership?
Old 05-05-2016, 10:23 AM
QSilver7's Avatar
Just curious because can't tell from your post...did you remove the module to check the areas not visible when it's mounted?
Also check the binder that contains the owners manual & other booklets if you haven't alresdy. The BT booklet also contains the PK code.
(SOLD)
Old 05-05-2016, 11:51 AM
No I didn't remove the module, afraid I'll pull or break something, assumed it would be placed on front. I bought the car used, so no Manual in the car. Previous owner doesn't know what happened to it.
Old 12-03-2007, 11:56 PM
Bimmer One Bimmer One is offline
Mein Auto: 04 X5 4.4
Is there just 2 nuts to remove on that cover to get to the unit?
04 X5 4.4
Premium Package
Sport Package
Cold Weather Package
Panoramic Roof
20" 4.6is rim upgrade
Navi
Bluetooth
Previously owned Bimmers...
99 convertible M3
95 325IS
89 325IS
Old 01-01-2009, 04:27 PM
thinkngrow thinkngrow is offline
Mein Auto: 2007 Alpine white 750li
i have an 07 750li and im really having a hard time removing the plastic cover, after removing each and every screw, it wont come off. i have a feeling nothing is under that plastic.
Old 07-09-2009, 11:12 AM
jamie98 jamie98 is offline
Mein Auto: 2006 750i
bt pass key
did you manage to get to the bt ulf in order to get the pass key.if so,let me know how you did it as i have a 2006 750i and i have a hard time finding the bt passkey.thx
Old 07-09-2009, 09:44 PM
bnolan06 bnolan06 is offline
Mein Auto: 2006 750Li
same here. I've looked in my trunk (06' 750Li) and unscrewed what I could, but no dice. help would be GREATLY appreciated.
Old 07-10-2009, 12:35 PM
Dropped by my local dealer today. They were able to look up my code through computer connection. 5 mins in/out. Better than tearing up the trunk and your knucles!
The passkey code can be read by connecting the car to the dealer's shop computer through menu option "Diagnostic Requests / Bluetooth Code" when DIS software 41 (March 2005) or newer is installed on the shop computer.
Old 08-01-2009, 12:53 AM
fdezone fdezone is offline
Mein Auto: X5
My wife recently purchased a previously owned X5. There was a 4-digit number written on the inside cover of several manuals but apparently, the manuals came from another vehicle! Joined this forum, performed a search and came accross this thread. I located the correct Bluetooth Passkey exactly where "King" said it would be (see Reply #2). The module is hidden under a black plastic piece on the floor of the trunk by the spare tire. You'll have to remove 3 screws to gain access. My sticker, however, read FK****. Hope that helps the next FNG.
Old 03-21-2010, 01:57 PM
DrewDomel DrewDomel is offline
Mein Auto: '06 330i
I also didn't get any documentation with my BMW about my passkey either so I have referenced this thread to try and figure it out. I have a PDF copy of the BMW Universal Bluetooth Handsfree System (ULF) and it advised me to hold down the send/recieve (little face) button for one second, start my car, continue holding for two seconds, and the display with show that my car is in pairing mode. Unfortunately I cannot proceed to the next steps because my car does not recognize bluetooth at all. I have tried every little thing to make it work and it doesn't. Does anyone know what I'm doing wrong? It is a black '06 330i.
Also, in order to find the passcode, do you have to actually remove that black plastic piece from the trunk pan by unscrewing the screws securing it?
I would greatly appreciate any help I can get!
Similar Threads
No Bluetooth Passkey card with my new 330i!! Lederman E46 (1999 - 2006) 5 07-31-2005 11:46 PM
Can anyone verify if these Bluetooth Retrofit Kit Part numbers are available? m3evolution General BMW Questions 25 06-22-2005 09:21 PM
Installed Bluetooth phone ....finally!(long) 03BMW330 Car Navigation, Audio & Electronics by BAVSOUND 15 05-30-2003 11:26 AM
Audi Accelerates Bluetooth Adoption ChrisTO General BMW Questions 0 12-10-2002 06:46 PM
