Old 03-18-2005, 12:17 AM
randyandy randyandy is offline
Mein Auto: 2001 330ci
door won't open
my passenger side door on my 330ci will not open from the outside. Yes I know how to take the door panel off and how to take the door handle off but I still can't see what's going on near the locking mechanism because it is buried deep inside the door. I believe that the problem is that the wire connecting the handle to the door latch has been displaced. Does anyone have any advice on how I can get to the problem. There must be a way to fix this. The solution is so close yet it is so far away dammit.
Old 03-18-2005, 01:26 PM
NH-SHICKS NH-SHICKS is offline
Mein Auto: 325i, 4Runner
I don't know how to fix it, but I just had both of those wire things replaced becuase they would freeze in the cold. Door would not open or shut in freezing weather.
It is called the carrier assembly
Steve
Old 03-18-2005, 02:22 PM
barcus barcus is offline
Mein Auto: 2006 BMW M3
same thing happened to me last week. I took it to the delaer they said a cable became unattached. took about 30 min to fix.
Old 03-19-2005, 10:02 AM
Rebe0912 Rebe0912 is offline
Mein Auto: 2004 325i sedan
Maybe someone can help me as well. I have a problem opening the back passanger door on my bimmer. The lock up but the door will not open. I think this may be some kind of interference from my IPAQ which contains a bluetooth. Then magically it opens. This gets fustrating as it doesnt always happen. Has anyone else had a problem and a solution for this. My BMW is a 2004 325i sedan. I have turned off the bluetooth but again it still happens. What could this be and what should I do? Is there some kind of antenna that goes with my car that I need to get? HELP ME!!
Similar Threads
Open diff vs. BMW pseudo-LSD EZ Motorsports, Racing & Track 10 02-18-2005 04:53 PM
Do people leave your door open? LeucX3 Off-Topic 11 02-18-2005 02:48 AM
How do you open the trunk?...without using key? sltahoe 3 Series & 4 Series 42 05-30-2003 09:14 AM
