Chip Questions. (1985 325E) - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 03-19-2005, 07:01 PM
Fragmaster170 Fragmaster170 is offline
Send a message via AIM to Fragmaster170
Mein Auto: 1985 325E
Hello,
I stumbled upon these forums on a random google search. As you can probably tell from the title I own a 1985 325E in great condition. It has under 100,000 miles and the brakes, clutch, wheels and tires have all been replaced within the past few months.
I am not a car person by nature, but am interested in learning more. Through my searches I have found these ECU chips and was wondering if it was worth it to buy one, what problems can happen with one, etc.
My main questions are:
1. Am I limited to Turner Motorsport if I want a quality chip?
2. Is it possible to solder both chips in and switch between them with a low voltage toggle switch?
3. Is switching to 93 octance gasoline necessary? What happens if I dont?
4. Do I need a new intake/exhaust/etc to take advantage of these chips?
***EDIT:
5. A friend of mine has suggested that I replace my current suspension (stock) with a lowering one, is this a good idea?
***EDIT2:
My apologies if E-bay links are not allowed on this forum.
6. I see some chips on ebay. These look to be copies of legit ones as the EEPROM's cannot cost more than $5 or so and the burner would only be around $150. Would these be worth it?
AC Schnitzer
http://cgi.ebay.com/ebaymotors/ws/eB...category=33597
Dinan
No Idea What Brand
Old 03-20-2005, 03:24 PM
pup's Avatar
pup pup is offline
Mein Auto: 89/94 325is 02 325i 05mcs
1. turner motorsport chips are excellent chips. i have had excellent results with one in a 325e as well as a 325i.
2. don't know, but there isn't a lot of extra room in the ecu, i suppose you would have to put the 2nd chip outside of the ecu.
3. if available, otherwise use the highest octane available in your area. you could get pinging and detonation using low octane.
4. no.
5. yes.
6. to the best of my knowledge, ac schnitzer has never made a chip. with ebay chips you can't be sure what you are getting or who did the programming. i wouldn't recommend them.
Old 03-20-2005, 04:06 PM
Could I switch back and forth? I dont mind buying a tank of Supreme once in awhile, but I would like to have a pocketbook left. Would it be possible to fill up with 93 octane gas, get down to a bout a quarter tank, switch ECU chips and go back to another one?
Similar Threads
Newbie questions Shabba E36 (1991 - 1999) 5 02-27-2005 07:35 PM
EAT chip for 95 525i with EWS is now available from Mark D'Sylva... read on Jeanfb 5 Series 1 08-04-2004 09:09 AM
Info and Some Questions... Deloriant 3 Series & 4 Series 3 07-09-2004 12:10 AM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 04:45 AM
First attempt at rock chip repair ChrisF The Detail Department 9 04-23-2002 01:01 AM
