E46 M3 (2001-2006)
Old 04-19-2005, 04:02 PM
Rudy@Tirerack's Avatar
Rudy@Tirerack Rudy@Tirerack is offline
Moderator
Mein Auto: 1-800-428-8355 X4664
Question for M3 guys with 19" who have gone wider than stock.
E46M3 of course
Unfortunately, after the sale we sometimes get very little feedback on how certain setups are working out. Rather than search, I thought it would be helpful for future reference to have them all in one thread.
Anyone care to post their own specific experiences in going from the stock 225/40R19 front, 255/35R19 rear to the wider 245/35R19 front and 275/30R19 rear? Did you find that the wider tires were mostly a cosmetic issue, did the tires tramline more, etc?
Thanks in advance for any feedback
Refer to 'Rudy/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by CLICKING HERE.
Rudy@Tirerack.com
Old 04-19-2005, 04:33 PM
16hr Day's Avatar
16hr Day 16hr Day is offline
Mein Auto: 2015 i3
Originally Posted by Gary@Tirerack
E46M3 of course
I would like to know if anyone is happy going larger than stock with the 18's too!!
2015 i3 Terra
2003 325i
2011 535i - SOLD
2003 540i-6 M-tech SOLD
1964 MGB Roadster
1980 International Scout II 345 v-8
2004 M3 Alpine White SOLD 2/14/09 We were in love
Old 04-19-2005, 05:24 PM
BahnBaum's Avatar
BahnBaum BahnBaum is offline
Empowered Consumer
Mein Auto: 1 - 4.20hp, 1 - 420hp
Very much so. I've gone to 265/35-18's all the way around on my stock 18s.
Alex
Interrobanged.
My Flickr
TeamWTF?!
Old 04-19-2005, 06:49 PM
bren's Avatar
bren bren is offline
///Mpty pockets
Mein Auto: wankermatic
My experience is with both 255's and 265's up front. The wider front tires tramline a bit more and also increase the steering weight/feel. If performance is your goal, larger front tires are absolutely worth it!
Old 04-20-2005, 09:54 AM
TD330ci TD330ci is offline
Lost
Mein Auto: 2003 M5
Are these on the stock 19's?
I was thinking about getting the 245/275 set up for my M3 I have on order and putting them on when it comes in. Is there any rubbing issues with those sizes on the stock 19's?
Old 04-20-2005, 10:32 AM
bren's Avatar
///Mpty pockets
Oops, forgot to specify that's on stock 18's. But I don't see how 18 vs. 19 would change things.
245/275 will fit fine.
Old 05-15-2005, 11:43 PM
Incendiary Incendiary is offline
Mein Auto: BMW
I made this size switch, went from the stock Continentals with about 7000 miles (about 60%-70% tread life left) to new Michelin PS2s. My observations:
- smoother ride
- tramlining about the same for large groves in the road, sometimes better if the groves are narrower than the tire.
- upsized tires sometimes tramline in small groves where the smaller tires didn't... but this is rare
- steering feels slightly heavier
- grip seems to be slightly improved... blasting down an on ramp with a turn I can keep on the throttle the whole way with the back just on the verge of breaking loose. Previously on that turn the Contis would start to break loose and I'd have to let up on the throttle a bit. Also, now I rarely break a tire lose from a stop, even when quickly exiting a business with a sharp right turn. With the previous tires it was easy to accidentally break one lose exiting a business.
- initial turn in seems slightly more vague... cuts down on my confidence level in the tires, so generally I don't think I go any faster than with the previous tires even though the apparently increased grip suggests that I might. This really gets to me on the tightest turns of my favorite twisty roads.
If I had to make the decision about tires and tire sizes again I'm not sure what I'd do. I like the improved grip, but I'd like the steering to feel like it has more bite when I crank the wheel. I don't know if the vagueness I experience is more due to a reduction in sidewall stiffness on the PS2s as compared to the Contis, or if it's due to the change in sidewall angles due to the wider tire.
Cheers,
Incendiary
Old 05-16-2005, 06:56 AM
bren's Avatar
///Mpty pockets
Have you tried varying the tire pressures? You'd be suprised what a few pounds of air can do.....
Old 05-16-2005, 09:35 AM
Mein Auto: BMW
No, not a whole lot. I'm currently running about the same pressure as I ran in the Contis... about 34lbs up front, and about 36lbs in back. Any suggestions?
Cheers,
Incendiary
Old 05-16-2005, 09:47 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
Cheers,
Incendiary
38-40 up front would make a huge difference.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 05-16-2005, 09:50 AM
bren's Avatar
///Mpty pockets
Cheers,
Incendiary
I don't have experience with the PS2 but the same pressure might not be ideal for 2 different tires. So just because that worked with the Conti's doesn't necessarily mean it will for the Michelins.
If it were me, I would swap those pressures....36 up front and 34 in the rear, or play with going up and down a couple pounds to see what happens.
And before you say it...yes I know BMW says to put more air up front but they are also the same people who put that tiny 225 front tire on there to begin with.
Old 05-22-2005, 11:52 PM
FlyingDutchMan FlyingDutchMan is offline
Mein Auto: 02' M3
On a properly built set of custom wheels, like CCW's that are machined specifically for the E46, you can fit a 275/30 on the front with a 19x10 rim like I have right now, no fender rolling needed if you run some negative camber. You could also go to a 295 tire on a 19x11 on rear, but you'll need to roll fenders
For the track a 275/285 hoosier combo workes nicely on my CCW race classics 18x9,5 and 18sx10.5. A better set up would be to get 4 - 18x9.5 or 10 inch wide rims and with 275 tires the whole way around so you can rotate them. WIth the right back spacing you should be albe to pull this off with no spacer or a very small 5-10mm.
Old 11-21-2007, 04:31 PM
anmeyman anmeyman is offline
Mein Auto: 2003 M3
Hey Technik, I have the same dillema as TD330ci. I currently have stock 225/40/19 and 255/35/19 on my m3, but would like to switch to 245s and 275s. What I am concerned about is that if i go with 275/30 the overall diameter of the wheel will come down to 25.5" as compared to 26" stock. If I go for 275/35 it will be bumped to 26.5" and am told that I will most likely need to roll the fenders. Do you know if reducing the OD to 25.5" can be a
problem, especially since my fronts will stay at 26" (ABS, DSC ???). I assume the odometer will be slightly off but I am not concerned with this at all. Thanks in advance.
Hella nice black M you got there!
Old 05-22-2005, 09:20 AM
HUMMM 3 HUMMM 3 is offline
Send a message via AIM to HUMMM 3
Mein Auto: 02 M3 Coupe, Topaz/Black
E46M3 of course
Don't know if you are still following this thread, but I have Dinan's 19" wheels (9.5F and 10R) with 275/30F and 285/30R S03's. No interference issues at all. Turn in was improved enormously. After nearly 20K miles (no track) the tires have become noisier and tramline more. I'm going to put PS2's on next week. (Nothing against the Bridgestones, but I'm looking for a softer ride with the Michelins.) BTW I also have Dinan's complete suspension set up including the camber plates. The air pressure discussion raised on this thread will have me experimenting with more air in the front.
2002 E46 M3 Dinan S3-R
Old 11-21-2007, 09:21 AM
michael clark michael clark is offline
hammertime550
Mein Auto: 07 550i 06 M3 ZCP
larger tires
I went to the 2753019 Pilots on the rear and have experenced no ill effects handling in the corners is noticelably better Only problem is now I want wider thiking about rolling the fenders or body kit to get to at least 2952520 or even 3052520
Hammertime
07 550i sport Mtech body/Black/Tan/Maya 20
06 M3 ZCP White/Cinnamon/IForged 19
Old 11-22-2007, 01:04 AM
Cowboy Bebop's Avatar
Cowboy Bebop Cowboy Bebop is offline
Mein Auto: M3
why?
to increace underateer, which the car has too much of already?
I am running 265f/275r and the steeering is so neutral that it is almost perfect.
I would want to decrease understeer- rather than increase it!
Life is like a B Movie, you wouldn't want to sit through it twice, but you'd hate to leave it in the middle!
Old 11-21-2007, 06:13 PM
sanhonda22's Avatar
sanhonda22 sanhonda22 is offline
Sleek Sam
Mein Auto: AC Schnitzer 745Li
XIX Type 05 - Front is a 19x8.5 with 235-35-19 Rear is 20x10 with 285-25-20 Tires. Lowered with h&r springs. Drives awesome. Gain in traction and handling.
Old 11-21-2007, 07:49 PM
bren's Avatar
///Mpty pockets
Originally Posted by sanhonda22 View Post
BLING
Oh, wait you're serious aren't you?
Old 11-21-2007, 08:01 PM
sanhonda22's Avatar
Sleek Sam
I dont think its blingy. Anyways, when the customer first wanted 20s in the rear, I was also thinking why, but when everything was all done and lowered, it looks pretty awesome in person
Old 11-22-2007, 05:35 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
That's why serious track and autocross people are running same size tires front and rear.
20" are pure bling, overall the combos are heavier and the lack of sidewall height reduces the ability to get the tread flat on the ground. Look at F1 cars, or pretty much any other race car, there needs to be some sidewall height to make the tire work best.
And there is a dearth of GOOD tires for thoses sizes.
If you are doing it for looks, fine. But for performance, you are doing the wrong thing.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Similar Threads
Question for the guys Mr. Sparkle Off-Topic 83 03-26-2003 02:58 PM
question for you guys & gals too. PMR55 Off-Topic 7 02-19-2003 04:15 PM
E46 guys, have a question for ya chukiechz 3 Series & 4 Series 1 06-27-2002 02:21 PM
Guys, this is probably the 1000th time this question is asked, but... ALEX325i General BMW Questions 3 01-17-2002 09:39 AM
Hey guys, another computer question: Is SDRAM the same as Ram AF Off-Topic 6 12-28-2001 11:36 AM
