5 Series DIY
Old 01-27-2005, 11:39 AM
Mobado Mobado is offline
Mein Auto: 1999 E39 528i
Oxygen Sensor 1999 E39
Hello all - I'm looking to do an oxygen sensor replacement for my 528. There are 2 pre and 2 post the catalytic converter. Looking for some insight into how difficult it is to DIY, resources for installation steps, etc., any help is appreciated. Thanks
Old 01-27-2005, 09:32 PM
DanB's Avatar
DanB DanB is offline
Officially Welcomed to the 'Fest!
Mein Auto: A bucket
The concensus is that you really don't need to do the post cat sensors, because the a/f mixture is based on the precat readings. I bought 2 02 sensors from autozone.com for around $62 ea.
Installation was a SNAP. Just jack the front of the car up and set it on stands. Then use a wrench to unbolt the 02 sensor from the exhaust, and follow the cord to a little black box. Use an 8mm ratchet to take the box off, unclip the connector, and you're set. Screw the new 02 sensor in, reattach the clip inside the plastic box, replace the box, and you're done. Other side is the same procedure.
-DanB
Similar Threads
Driving Impression E60 from an E39 owner beewang General BMW Questions 24 10-14-2004 07:52 PM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 05:45 AM
Wide Picture from the Bimmerfest run, lookout point mola 5 Series 8 04-16-2003 09:54 PM
Last Date for E39 jim628 Regional Forums 1 01-13-2003 07:38 PM
~*(New Version)*~ The BMW E39 FAMILY !! - check it out =) Jimmy540i.com General BMW Questions 0 08-05-2002 12:25 PM
