Old 02-08-2005, 10:31 PM
dmel dmel is offline
Send a message via AIM to dmel
Mein Auto: 2005 330xi
bluetooth user's guide?
I just picked up my 2005 330xi today and stopped by the service desk to ask if there were instructions on how to pair a phone to the BT in the car. They said it was covered in the owner's manual, which it's not.
I don't have a BT phone yet... I was hoping to try friends' phones to see if they work well before splurging on the V710 and flashing the hacked firmware.
I haven't looked at the owener's manual CD-ROM, but there's no info in the printed manual.
Thanks!
Old 02-08-2005, 11:33 PM
Bob Clevenger's Avatar
Bob Clevenger Bob Clevenger is offline
ex-M couper
Send a message via Yahoo to Bob Clevenger
Mein Auto: '06 650i Coupe
My BT setup is not factory installed, and it's a 2004 to boot.
But it works very well with my Motorola V600 without any tweaking at all.
Check out your CD manual. You might also look under something connected with "Voice Input" or similar.
I have the manual for the BT that I installed in my '04, and if you can't get one out of your dealer I'll be happy to try and scan it for you.
Bob, Lord Helpus, KtR
Monaco Blue 650i coupe; 6MT, HUD, ACC, ZCW, ZPS. Redelivered 20 July 2006
Old 02-09-2005, 12:11 AM
Robbyrh10 Robbyrh10 is offline
Send a message via AIM to Robbyrh10
Mein Auto: 330ci ZHP
I have the RAZR Motorola with Bluetooth and I cant seem to connect it with my 2005 330ci zhp. I really wanna get this hooked up. Any help would be much appreciated. Thanks
Old 02-09-2005, 12:38 AM
hecklerz's Avatar
hecklerz hecklerz is offline
Mein Auto: '07 E90 328i
If bluetooth is active in your 330 then it should be 'Discoverable' by your Moto. Set the phone to search for a bluetooth device while the car is running. When/if it finds it it will show up as "BMWxxxxx" and ask for a pairing passkey (found on a card included in your manuals binder). Enter the key and you should be set. I've read that you shpuld power of the car for 3 minutes after pairing, but I didn't have to do this with mine. One issue you may have is when the phone begins to transfer the sim card phonebook to the car (it will have to do this before you can start making calls). This has been noted to take anywhere from 5 to 40 minutes so be patient. I have a Sony T637 not a Razr- the Razr is known to work- and mine works great. Hope this helps, good luck!
2007 E90 328i | Metallic Black | Black leather | Heated seats | 6-Sp. Step. | ZPP | ZSP | NAV- iDrive | Adapt.-Xenon | Prem. audio- CD changer | Burl trim | BT to iPhone
**Looking for an E39 540, 530 or X5
Retired:
*2006 E90 325i- Ti-Silver Metallic, Black leather, Heated seats 6Sp Step. , ZPP, ZSP, NAV, Adapt.-Xenon, BT to iPhone
*2004 E46 325i- Silver Grey Metallic, Black Leather- heated, 6sp Step. , ZSP, ZPP, Xenon, Nav- V.26, BT to Blackberry
Old 02-09-2005, 07:56 AM
So this is the procedure... very helpful! I haven't found a card that lists a pairing passkey... I'll call service today.
Thanks!
Old 02-09-2005, 11:14 AM
blockpavick blockpavick is offline
Mein Auto: 2005 325xiT 5spManual
Thanks!
Here is the website for all the information you need: http://www.bmwtis.net/tsb/bulletins/...p/B841304g.htm. Scroll to the end, and you will see a link to PDF files including a file for the Bluetooth Manual. This has been posted in other threads here before, and a bit of a search effort should have found it! My Cingular Motorola V551 has paired and worked fine with my 2005 325xiT. Good luck.
Joe B.
Old 02-09-2005, 12:33 PM
Joe B.
Thanks Joe. Should have RTFM... i appreciate the link.
Similar Threads
Can anyone verify if these Bluetooth Retrofit Kit Part numbers are available? m3evolution General BMW Questions 25 06-22-2005 09:21 PM
Installed Bluetooth phone ....finally!(long) 03BMW330 Car Navigation, Audio & Electronics by BAVSOUND 15 05-30-2003 11:26 AM
Audi Accelerates Bluetooth Adoption ChrisTO General BMW Questions 0 12-10-2002 06:46 PM
