Old 02-08-2005, 10:50 PM
BMW_Brand BMW_Brand is offline
Mein Auto: 2004 BMW 325i ZSP
Why oh why only one way down...
Being able to open all the windows and moonroof from the remote is nifty-- but it would be even nicer if I could close them also...
(As far as I know that isn't possible right?)
Old 02-08-2005, 10:53 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
iWindows
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline
1988 M6 Royalblau/Silbergrau Nappa
Old 02-08-2005, 11:43 PM
e36M3r's Avatar
e36M3r e36M3r is offline
Mein Auto: e46 M3
As you probably know, from outside the car, with the key in the lock you can put them up.
Old 02-08-2005, 11:55 PM
dynosor's Avatar
dynosor dynosor is offline
Back from walkabout
Mein Auto: 2003 E46 330i
Very simple. Its for safety
If you stood somewhere in range and closed the windows, but could not actually see the car, you might pinch someone and hurt them.
Closing the windows with the key in the door lock implies that you are close enough to verify no bystander risk.
This may seem silly, but considering how many people inadvertantly open all widows by pressing the unlock button of the remote in their pocket without intending, they might just as easily close the windows unintentionally.
Old 02-09-2005, 07:55 AM
Truthfully, that's what I figured BMW's reason was. However the windows do have sensors I believe, so something like that wouldn't happen...
The whole reason I brought this up is because my friend's A4 has the ability to do it
Old 02-09-2005, 08:19 AM
Jim H's Avatar
Jim H Jim H is offline
Mein Auto: '98 323is/'70 TR6 PI
OK, I know this is probably in my manual somewhere, but how do I do both of these...opening the windows remotely, and closing them (even with the key in the door)?
Thanks!
-Jim
My Rides:
1998 BMW 323is: Arctic Silver/grey, 5 spd, premium package, etc.
1970 Triumph TR6 PI: Euro-spec, 4 spd w/electric overdrive, 2.5L I-6 w/petrol injection
Old 02-09-2005, 08:25 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP & 04 Honda VFR
Thanks!
-Jim
To open remotely: hold down the unlock button.
To close: Stick key in driver's door, turn 90 degrees clockwise like you would to lock the doors - only keep the key in that position while the windows go up.
Like Kaz said, you can purchase iWindows which will let you roll the windows up with the remote. I have it, it works as advertised. Installation takes roughly 30 seconds (if you have NAV... otherwise, maybe 5 minutes because you don't have the left panel access door inside of the trunk).
http://www.tvonnav.com/iwindows.html
Old 02-09-2005, 08:38 AM
Jim H's Avatar
Hmmm. Thanks for the info. I tried to roll the windows up the other day by putting the key in, turning it, and holding it, and it did not work. Perhaps I did not hold it long enough? I'll have to try again...
My Rides:
Old 02-09-2005, 09:36 AM
Originally Posted by Kaz
iWindows
I thought that was some sort of joke. I checked out the site on iWindows. AMAZING! I am definately getting it. Thanks!
(For those who want to see a video of it, go here http://www.burntsheep.com/tvonnav/iwindowsdemo.wmv )
Old 02-09-2005, 09:50 AM
cwsqbm's Avatar
cwsqbm cwsqbm is offline
Dreaming of Track Days
Mein Auto: ED'd 330Ci / E30 325i
I conidered them, but because of this info under the coupe section:
Originally Posted by Iwindows website
When windows are put up using the iWindows Module the windows will go down the 1/4" when the door is opened, however the windows will *not* go back up the 1/4" when the door is closed.
I'm leary of the window not going back up. What, now I have to manually put the windows up the last 1/4" when inside car? The other problem is pinch protection is not active.
.................................................. ............................................. Space for rent .................................................. ..........................................
Old 02-09-2005, 10:08 AM
The site says that 1/4" problem is only for coupes-- good thing I have a sedan
The lack of pinch protection does pose a problem, will just have to make sure no one is around I guess...
Old 02-09-2005, 02:19 PM
SikUnt330Ci SikUnt330Ci is offline
Mein Auto: 330Ci
You can close the windows:
-with the remote without iWindows
-without having your key in the lock
I do it on mine all the time
when your Windows/Moonroof are open, lock the car with the remote
Then press the lock button again, but hold onto it this time.
Give it a couple of seconds and all windows/moonroof should start to close.
Old 02-09-2005, 02:34 PM
KrisL's Avatar
Ubergeek
You can do this because you are not in the letigious USA. Here, roll-up w/ remote is disabled .
Old 02-09-2005, 02:51 PM
andy_thomas andy_thomas is offline
Mein Auto: 318i
...this implies that only a re-code of the central body electronics module (or the E46 equivalent of whatever controls the windows) stands between you and remote roll-up windows.
Old 02-09-2005, 02:53 PM
Mein Auto: 330Ci
Well that kinda sucks then...
You have to purchase a 3rd party product to use a "Disabled Function" on your vehicle.
Old 02-09-2005, 03:03 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Apparently this has been researched to death with no results, hence the aftermarket products.
Old 02-10-2005, 12:14 PM
AndDown's Avatar
AndDown AndDown is offline
just copacetic!!!
Mein Auto: 2013 328i, 2003 325i
Because there are too many lawyers here in the good US of A looking for work
Dan
'03 325i OrBlu, MT, PP, SP
'01 X5 3.0 AlpWhite, AT, SP, CP
'89 325i Bronz, AT(retired)
'02 325i StlGrey, AT, PP, SP
'13 328i AlpWhite, AT8, Xenon, HK
Old 02-10-2005, 04:28 PM
rgzimmer rgzimmer is offline
Mein Auto: '10 328i; '09 335i
Like this could ever happen with the < 10' range of these crappy remotes. I can see insde my car by the time my remote is in range.
Of course, there's always the chin tric to get around it, though.
<img src=http://www.bimmerfest.com/forums/picture.php?albumid=2304&pictureid=10885 border=0 alt= />
__________________________
1993 325i - Gray/Gray (sold)
2004 325Cic - Gray/Gray (sold)
2005 330Cic White/Saddle (sold)
2006 330i - TiAg/Black (sold)
2009 335i E90 M Sport Space Gray/Chestnut
2010 328i E93 Alpine White/Saddle (sold)
2012 X5 35d Black Sapphire/Cinnamon
