Old 03-11-2005, 12:51 AM
van_basten van_basten is offline
Van Basten
Mein Auto: 01' 330ci
Help: sluggish shifting
In the past couple weeks I have been having hard time shifting. Shifting into all gears feel very sluggish. It feels like it gets stuck but doesn't produce noise. A lot of time I can't shift all the way and I need to pull back to neutral, release and re-engage clutch and reshift again in order to get it into gear. It seems to getting worse.
Could this cause by my clutch? The thing is the clutch doesn't slip at all. My car is a '01 with 50k miles, original clutch, out of warranty. And I don't abuse my car.
Old 03-11-2005, 07:16 AM
bluetree211's Avatar
bluetree211 bluetree211 is offline
Send a message via AIM to bluetree211
Mein Auto: Z4MC
needs new transmission fluid?
Old 03-11-2005, 07:56 AM
DZeckhausen's Avatar
DZeckhausen DZeckhausen is offline
Send a message via AIM to DZeckhausen
Mein Auto: 2012 BMW F30 328i 8-Speed
New transmission fluid may help, but I'm suspicious that the problem crept up over such a short period of time.
Try replacing the "lifetime" tranny fluid with two bottles of Royal Purple Synchromax. You'll need just slightly less than two bottles. Use a 17mm 6-point socket and a long breaker bar to get the drain and fill plugs off. (Not in that order, of course!) And you'll need a small fluid transfer pump such as the kind you can pick up at Pep Boys or NAPA for $6. Fill the tranny until fluid overflows and starts to run down the side of the case.
While you're under the car, inspect the linkage between the bottom of your shift lever and the top of the tranny.
Hopefully, the new fluid will cure what ails your car. If not, then you may have some clutch issues cropping up. Keep your fingers crossed!
Dave Zeckhausen
Owner, Zeckhausen Racing
2015 BMW X1 xDrive28i M Sport
2012 BMW F30 328i Luxury Line 8-Speed
StopTech 4-wheel big brake upgrade
2001 BMW E39 540i 6-Speed (Traded-in for F30)
CDV deleted
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
Trouble with smooth shifting - E46 M3 Xiled1 1M & M2 35 08-10-2005 07:10 AM
Steptronic Shifting BIMMER4LJ 3 Series & 4 Series 29 09-22-2004 11:29 AM
Proper 1-2 shifting technique? cokray 3 Series & 4 Series 41 05-20-2003 08:44 AM
Properly sized front shifting arm bushings Ron Stygar E36/7 Z3 (1996-2002) 2 08-19-2002 02:32 PM
