5 Series DIY
Old 03-14-2005, 09:23 PM
batmanm3 batmanm3 is offline
Mein Auto: 02 m3
rear main sunshade help wanted
Somehow the rear sunshade tab has retracted itself almost flush with the door panel. I can pry it up somewhat, but fear breaking something...either the shade or the door panel.
I'm guessing that I need to remove the door panel to access the window shade...how do I do this? For a neophyte DIY is this particularly difficult?
Any little bits that fall out and disappear that are critical to the reassembly?
Old 03-15-2005, 11:55 AM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator 5-Series
Mein Auto: Trek 6500 MTB
I haven't removed a rear door panel but I have a front. You just need to go slowly and carefully and make sure that you take all the fasteners out. Anything that need prying, try to use a piece of wood (ruler, popsicle stick, chopstick) because it is softer than a screwdriver.
Start with the armrest/handle on the door and look carefully for screws or the little pieces they use to hid the screws.
Old 03-15-2005, 03:19 PM
Tyrone Tyrone is offline
Mein Auto: '97 540i
The shaded rear door panels are secured to the door in lots of places. Nothing like the standard ones! Follow these steps otherwise you will surely break or stress something.
1) Remove quarter window shade assembly. Insert tiny slotted screwdriver into the slot at the top to release the spring clip holding it on. Push clip upward.
2) Once quarter window shade is removed, 3 screws will be visible on the metal partition. Remove the lowest screw, which secures the bottom clip.
3) Remove the wood trim on the door. You will see two holes at the outer edges. Inside these holes are two black Phillips head screws. Remove. Do not remove the two EXPOSED gray screws. You only want to remove the ones in the holes.
After that is done, you can proceed to remove the door panel as you would a standard one--pop the plastic screw cover off behind the door lever, pull top of panel away from door molding, remove electrical connections, etc.
Similar Threads
E65 V12 debuts nate General BMW 21 07-14-2004 09:04 PM
Rear Sunshade Craps_Player Ask-A-Dealer 1 02-29-2004 12:04 PM
Group Buy of replica CSL truck lid and rear diffuser LandShark Classifieds 0 02-26-2004 12:53 PM
325 Rear Sunshade Option (US) MMME30W Ask-A-Dealer 3 09-04-2003 04:31 PM
Can't order rear sunshade Khuzud General BMW 6 12-26-2001 10:39 PM
