Old 03-09-2005, 12:34 PM
dcrocker dcrocker is offline
Mein Auto: 2005 330i
Clicking noise (switch???) on clutch pedal release (2005 330i)
Sometimes, after I first start the car, I hear a distinct clicking noise
when I release and press the clutch pedal. It sounds exactly like a switch being
pressed and released. It coincides with a specific position of the clutch pedal and the
sound is coming from somewhere in the area of the pedal. It goes away a very short
time after I drive away and doesn't seem to come back until I get back in the car
after some time. It doesn't happen all the time. And, it doesn't seem to affect the
performance of the clutch.
Any idea what this is? Sorry if this has been covered, but I was unable to find a similar
issue after doing a search.
Old 03-09-2005, 01:34 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2014 535i
I also have an '05 330i with about 1800 miles. I've noticed that exact noise on only a couple of occasions. Once I kept pressing it just to be sure I did hear it, and it was just as you said. Other than the starter interlock, the only thing I can think of is the cruise control disengage switch--maybe it makes a slight noise when the switch is cold? But then again, it is very inconsistent even at various temperatures.
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Old 03-09-2005, 01:44 PM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
The cruise control switch IS the starter interlock. If it's there all the time, I would think it's the interlock although after MY 01 the interlock has been integrated into the clutch master cylinder and it's magnetic, not switch based.
If you search for "clutch" and "click" on this forum, you should find some description of a problem BMW had with a throw-out bearing issue on 02-03 manuals, in one of the threads the TSB number and description of the problem is given. Sorry, but I'm not going to ATYCLB the link for you, you'll need to look for it yourself.
Old 03-09-2005, 02:06 PM
markl53's Avatar
So it is one single switch for the cruise and starter interlock? ok.. Also, for me, the noise is definitely inside the car so I think it's local to the clutch pedal action and not a bearing noise, just IMO.
BMW-CCA
Old 03-10-2005, 11:54 AM
Ok, I found the thread you're referring to. I guess I limited my seach to the E46
subgroup but found the thread when I searched more groups. There is no
pedal feel related to this sound, just a clicking noise. I agree that it's likely the starter
interlock switch. This morning was quite a bit warmer than yesterday and there
was no sound. So, maybe it's temp related or maybe it's just random. I'll keep
my eye (ear? ) on it and maybe mention it to the dealer.
By the way, what does ATYCLB mean? Am I too old to get it?
Thanks.
Old 03-12-2005, 06:38 PM
minig0d minig0d is offline
Mein Auto: 2001 BMW 325xi
Have your dealer bleed your clutch line... fixed my clicking/popping noise
Old 03-12-2005, 07:47 PM
Scott ZHP's Avatar
We want the Lion!
Thanks.
Welcome to the Fest. I have the same noise on my 03 and I'm nearly certain it is the starter interlock. Try to start the car with the pedal just north of the click and it probably wont, push down a bit further after the click and it will.
ATYCLB is a bimmerfest member. For reasons unbeknownst to most of us, he lives to police the boards for reposts. Best to ignore him.
Old 03-12-2005, 11:26 PM
FenPhen's Avatar
FenPhen FenPhen is offline
It's Highly Addictive!
Mein Auto: 2004 330i ZHP
If you're doing forum-limited searches, use "3-series" instead. The E46 forum has only been around a couple months. This is probably the biggest problem with shuffling forums around is messing up search results and locking old (but relevant) threads closed to posting replies.
"All That You Can't Leave Behind," a U2 album released in 2000. (In this usage, a Bimmerfest member.)
2004 330i 6MT · performance package · silver gray · alcantara/cloth · black cube · xenons · pdc · aux audio
Old 03-18-2005, 06:34 PM
markl53's Avatar
Found the answer...
OK, tonight I finally put 2+2 together and realized when my clutch makes the clicking noise. Now that I know the answer, I can make it happen at will. The "switch clicking" noise occurs only during the period when the seat belt chime is going off after just starting the car. Once the chime stops, so does the clicking. Try it -- start up in neutral (no seatbelt) and immediately press and release the clutch a few times while the seat belt reminder is going. You'll notice the clicking stops when the chime stops. It's as though a switch is placed into position to sense starter interlock for the few seconds and then removed. If this is true, those Germans are more fanatical with engineering than I even imagined! (I mean that as a compliment).
Oh, I haven't yet tried it with my seatbelt fastened to see if it's specifically a time thing or directly connected with the chime function -- maybe later...
BMW-CCA
Old 03-19-2005, 12:01 AM
Interesting...
Well, I always fasten my seatbelt before I start the car and the clicking still happens
then stops after a bit. I will play with it tomorrow, but from my experience, it's not tied to
the chime itself, but maybe to some timer related to the chime.
I do find it amusing and a little silly that we even care about this. I guess it's a mystery
to solve...
Old 03-19-2005, 02:00 PM
markl53's Avatar
Partial retraction :)
Interesting...
to solve...
Umm, today I noticed it kept clicking a little while after the chime stopped, so I need to retract that part . But, I still say it is some time-related thing upon startup...I don't like to leave wrong info, especially when I said it .
BMW-CCA
Old 03-19-2005, 04:05 PM
Sorry, but I heard it after drving for a while. Very strange...
And, for those inclined to flame, I can assure you that I'm mostly curious as opposed
to worried. However, I'm losing my curiosity pretty quickly .
Old 03-20-2005, 11:40 AM
Orient330Ci Orient330Ci is offline
'Fester
Mein Auto: 2002 330Ci
The clicking happens at random in my '02 330Ci
Similar Threads
Strange clicking noise, please help! mark155 E34 (1989 - 1995) 9 10-22-2007 08:53 AM
"Pop" in clutch pedal normal? toddkageals 3 Series & 4 Series 24 06-04-2003 08:23 PM
clicking clutch pedal 10chi 3 Series & 4 Series 9 02-14-2003 11:34 AM
"Air Puff" / "Whoosh" Noise from Clutch Normal? JawKnee 3 Series & 4 Series 5 11-07-2002 08:48 PM
"Air Puff" / "Whoosh" Noise from Clutch Normal? JawKnee General BMW Questions 1 11-07-2002 06:29 AM
