E46 (1999 - 2006)
Old 03-18-2005, 11:29 AM
Will_325i Will_325i is offline
Mein Auto: 2004 325i
At what RPM should I shift for max accel?
I'll be honest, I'm asking mostly just for curiosity. I usually just "feel" when it's the right moment to shift. At any rate, I find that often this "point" is very close to the rev-limiter.
I assume each gear should have a slightly different optimum rpm to upshift.
Thoughts?
Old 03-18-2005, 11:39 AM
BlackChrome's Avatar
BlackChrome BlackChrome is offline
Mein Auto: '02 E39 M5
I'd say right before the fuel cutoff (so, um, 6500RPM).
IMHO, the reason why so high, is because when you shift to the enxt gear, the RPM won't drop too low (when compare to, say, 5500RPM).
Please correct me if I am wrong.
2002 E39 M5 Chiaretto Red/Caramel extended leather
Old 03-18-2005, 11:50 AM
I totally agree, but then the problem becomes statistical.......how many times out of a hundred can you shift within 100 rpm of the limiter without actually reaching the limiter?
I would guess, though, that if two gears are very close in ratio that it may not be necessary to go so high in rpm.
Old 03-18-2005, 11:52 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
In a BMW, the limiter.
But generally speaking, it depends on the torque curve.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 03-18-2005, 01:24 PM
JAWJr's Avatar
JAWJr JAWJr is offline
Le plaisir de conduire
Send a message via AIM to JAWJr
Mein Auto: All Manuals
Originally Posted by rumratt
What he said.
They only way you would shift earlier than redline is if your torque drops of quite a lot at higher rpms. The increase in torque gained from shifting (by moving back to the torque sweet spot) would need to outweight the gearing disadvantage of the higher gear. With a realtively flat torque curve, this ain't gonna happen, particularly for the lower gears where the difference between gears is huge.
I'll third that- what you should do is search for a dyno chart of someone's car that has the same engine as yours, and see where your power drops off. That'll show a visual of what you're looking for.
~Jon
2013 135is | Le Mans / Black w/ Blue stitching | Manual | Premium | HK Sound
1991 318is | BrilliantRot / Natur ette' | Manual | Fogs | Sunroof
2009 135i Cp | Alpine White / Black Plastic Cow | ZSP | ZPS SOLD
2007 Z4 R 3.0i | Silber Grau / Dream Red | ZSP | 711 | 522 | 494 SOLD
2007 335i Cp | A61 / LCSW | ZPP | ZSP | 322 | 4AS | 609 | 655 SOLD
2005 DINAN 330Ci | Silber Grau / Alacantara | ZHP | ED 12.10.04 SOLD
Old 03-18-2005, 02:38 PM
TeeKay TeeKay is offline
Mein Auto: M & M
Look at the flasing lights...
The flashing light on the tach should flash madly to indicate when the optimal shifting point should be. It's pretty neat. It was on the M3 I test-drove. I don't remember it being on an Auto 325. What about the other manual 3-series, do they have this feature?
Old 03-18-2005, 08:16 PM
cwsqbm's Avatar
cwsqbm cwsqbm is offline
I do'nt make mistakes.
Mein Auto: Quadricycle
What he said.
Actually, torque dropping off isn't really the issue as much as horsepower dropping off. When you shift into the next gear, the engine may make more torque, but it has less gear multipication. You want to shift when the horsepower in the current gear is less then horsepower in the next gear. However, in most modern cars (BMW's included), that point is beyond the manufacturer-imposed redline, so shift at redline. Of course, there are examples against this, but most are large domestic V-8's that aren't optimized for high rpm breathing.
.................................................. ................................Garrison-Jenner 2016 .................................................. ..........................................
Old 03-18-2005, 08:29 PM
Originally Posted by cwsqbm
However, in most modern cars (BMW's included), that point is beyond the manufacturer-imposed redline, so shift at redline. ....
Is that because of a flat torque curve AND big gear ratio differences? I mean in a CVT the car should never reach redline. Right?
Old 03-18-2005, 08:38 PM
Plaz's Avatar
Plaz Plaz is offline
Mein Auto: '11 1M;'08 MCS;'02 325iT
No.
2011 1M
2008 MCS
2002 325iT
Old 03-18-2005, 08:42 PM
Mr. The Edge's Avatar
Mr. The Edge Mr. The Edge is offline
Mein Auto: .
it's not even on all M3's
Old 03-19-2005, 01:41 AM
Alex Baumann Alex Baumann is offline
Ex-Dictator
Mein Auto: Saab
Objection to the shifting light idea ! This is not a race car.
I don't understand the trend to make the 3 Series car into a race car. It is not and it was not meant to be a race car
"Effective leadership is not about making speeches or being liked; leadership is defined by results not attributes."
Old 03-19-2005, 01:49 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
Some of us have been adding a shift-up warning to our E36s. I think it is neat and keeps me from hitting the rev limiter when I overtake. It also once saved me from an over-rev while I was still developing it. Arguably, that only happened because I was developing it. Still, it may easily pay for itself some day.
Old 03-19-2005, 06:06 AM
Moderato's Avatar
Moderato Moderato is offline
VIII
Mein Auto: 07 E92 335i 6MT
6500 rpms which is redline in my car. I usually shift just a little before so I don't break anything.
Old 03-19-2005, 09:16 AM
johnnygraphic's Avatar
johnnygraphic johnnygraphic is offline
Mein Auto: 330i Performance Package
The only flashing light I see is behind me!
Old 03-19-2005, 03:00 PM
Artslinger's Avatar
Artslinger Artslinger is offline
BMW + twisty road = fun
Mein Auto: Car
I like to shift between 4000 - 4500 rpms.
Old 03-19-2005, 03:34 PM
I'm turning one into a race car.
Old 03-19-2005, 04:06 PM
cwsqbm's Avatar
If we don't occasionally "race" our cars, why don't we all drive 318i's instead of all the 325i's and 330i's in the U.S.?
Its not the ideal race car, but for some, our cars need to be multipurpose. So my 330 will see a little driving school, a little autox, and an occasional blast down the interstate. I'd love a separate car for each, but I've already run of out of parking.
Also, the shift light is a good idea because I don't shift at redline on most drives, so I'm not tuned to it like I was on old, slower cars that required aggression just to keep up with traffic. Plus, its so smooth compared to other cars I drive (nothing like a Chevy Classic to make coming home to a BMW feel so good.)
Old 03-19-2005, 08:55 PM
RSPDiver's Avatar
RSPDiver RSPDiver is offline
Ich bin ein Bimmerer
Mein Auto: 04 ZHP/4
I'll bet you can't wait till she's broken in, huh?
Since you stand to gain/lose thousandths of seconds by the exact right shift point, I would suggest investing in multiple runs at the track where you are performing these race maneuvers. You aren't doing this on the street, are you? I mean, on the street you *shouldn't* be racing, especially past the posted speed limit (which means one shift, 1st to 2nd in pretty much every instance), and the difference in the shift point will mean the difference of almost nothing.
Old 03-20-2005, 10:12 AM
Orient330Ci Orient330Ci is offline
'Fester
Mein Auto: 2002 330Ci
The 3-series are great performers, and I know, BMW's are meant to be driven.
But do you guys push your cars this hard all the time? If you're pushing close to redline all the time then you're hauling ass way over local speed limits. No?
Were all these posts talking about track time? Or am I just not driving fast enough?
Old 03-20-2005, 12:10 PM
Ex-Dictator
Mein Auto: Saab
[Alex Mode On]
I race on the Autobahn, I race it as much as possible. I'm a devil on the unrestricted sections, but I never felt the need for a shift light. I just shift by feel. I know when it's time to shift.
[Alex Mode Off]
PS : What makes you think that you can't race a 318i ? I saw a lot of underpowered cars upsetting horsepower monsters on the track.
Old 03-20-2005, 12:11 PM
Ex-Dictator
Mein Auto: Saab
That's the key word
Old 03-20-2005, 01:43 PM
FenPhen's Avatar
FenPhen FenPhen is offline
It's Highly Addictive!
Mein Auto: 2004 330i ZHP
Onramps.
Some onramps have high visibility where you can see traffic flow. You can push hard and get into 3rd aggressively and still shut it down around 75 before you merge (or get spotted by a cruising cop).
2004 330i 6MT · performance package · silver gray · alcantara/cloth · black cube · xenons · pdc · aux audio
Old 03-21-2005, 08:48 AM
brave1heart's Avatar
brave1heart brave1heart is offline
Lap Dog
Mein Auto: '08 Z4 M Coupe, '01 325i
Exactly!! Every 1 mph gain in exit speed is a 1 1/2-ft gain over every second of acceleration on the straight. If you can manage exit speed of, say, 5 mph faster than that HP monster, not only are you gaining in the turn but you will be gaining 7 1/2 ft for every second of acceleration on the straitway. Sure, their HP will kick in on the straigtway but first they have to catch up to that 5 mph difference AND then reach a higher speed than the 318 AND carry that high speed for a bit to offset the time the HP monster already lost. On tighter tracks, a 318 can do pretty well. On track with long straightway long Road America, though, top end would be a huge disadvantage.
'08 Z4MC, Interlagos Blue, Black int, CF trim, H&R springs, TMS camber kit w/ -3 deg, 245/275 Nitto NT01 on D Force LTW5 wheels, 245/275 Dunlop Direzzas
'01 325i: Orient Blue/black, SP, M stress bar, UUC sways, TMS camber plates, TMS rear sub reinf kit, CAI, Shark, Borla, Dunlop Direzza 245/40/17 on 17x8 O.Z. Superleggeras
HPDE instructor, Boston Chapter Autocross Co-chair, Boston Bimmer columnist www.boston-bmwcca.org/bimmer/online.aspx
My performance driving site: www.OneHotLap.com
Similar Threads
A purist review of SMG II nate General BMW Questions 30 03-25-2013 05:47 PM
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW Questions 7 07-19-2006 04:52 PM
My review: Rogue Octane vs. UUC EVO3 Serbonze 3 Series & 4 Series 7 07-15-2004 08:24 PM
Need a picture of 6000 RPM PunchIt Off-Topic 22 11-19-2003 01:06 PM
1 to 2 shift in 330i (at around 4000 rpm) mecklaiz General BMW Questions 32 07-28-2003 02:33 AM
