Old 03-21-2005, 07:08 PM
billy mo billy mo is offline
Mein Auto: 2004 530i
Dash Light
Had an issue today with my dash lights. The car lit up (red representation) and a red light lit up in the top right corner of it. It lasted about 5 minutes and went off. It happened again later then stopped all together. Does this mean I have a light out or since it stopped happening, maybe a confused car?
Old 03-21-2005, 07:33 PM
doeboy's Avatar
doeboy doeboy is offline
DHP pwns ZHP :p
Mein Auto: DHP Heehee... :p
Could be one of the bulbs, or it could be the holder that the bulbs sit in is getting flaky or a bad connection that needs cleaning.
'03 330Ci DHP
'06 M3 SMG
"du hast mich gefragt, und ich hab nichts gesagt"
Old 03-22-2005, 08:56 AM
Salvator's Avatar
Salvator Salvator is offline
Livin' like Larry!
Mein Auto: 2007 328XiT; 2008 328 CiC
The bulbs sometimes melt their solder on to the bulb holder, leading to intermittant false "burned out" indications... Usually, a new bulb and socket (don't worry, it's only about $7 for a front turn indicator socket, assume similar for the rear) are the cure... if the rear socket is more expensive, take some emory paper and scuff off the solder on the socket, and install a new bulb... If you are still under warranty, take it to your dealer and they should handle it under warranty...
Old 03-22-2005, 10:22 AM
chopper chopper is offline
Mein Auto: 2000 328i, 89 325i
My E30 does this all the time. Light corrision in the bulb socket is also a possible cause.
Similar Threads
Abs/asc Light On - Please Help!!!!!! Avatar1 5 Series 11 01-26-2005 01:23 PM
ACS traction light and ABS light are on-Help blaze7716 5 Series 2 12-10-2004 06:46 PM
e46 auto shift light goes funky AuricanX 3 Series & 4 Series 4 12-26-2003 07:34 AM
Hmm, E46 facelift suppose to get LED rear lights Alex Baumann General BMW Questions 20 11-19-2002 12:58 AM
dash light appears ashecnc General BMW Questions 30 01-06-2002 04:53 PM
