E30 (1982 - 1993)
Old 04-03-2005, 04:15 PM
cs1221 cs1221 is offline
cs1221
Mein Auto: 1991 318is
Antenna fix
I need to replace the seal on the power antenna. It is just a little piece of fubber that fits where it meets the body. This piece costs all of $1.50, but my mechanic said it takes about an hour 1/2 of work because you have to pull the whole thing out for some reason. My question is: Does anyone know what steps I would need to follow to accomplish this? Any help would be appreciated.
Thanks!
Old 04-03-2005, 05:38 PM
pup's Avatar
pup pup is offline
Mein Auto: 89/94 325is 02 325i 05mcs
look behind the interior trim in the trunk. you will see where the antenna mounts up. i can't remember for sure, i think it is two or three bolts. unsecure these bolts as well as the metal collar on the outside (the one that goes around the mast above the gasket). then it should just slide out, you might need unclip the wire harness as well.
do this with the antenna in the down position. should be super easy and about a half hour max.
Old 04-03-2005, 09:46 PM
AndDown's Avatar
AndDown AndDown is offline
just copacetic!!!
Mein Auto: '16 428i GC
Did mine not too long ago - pulled the interior carpet trim back and unbolted the antenna unit as described by pup. I didn't have to remove the metal collar as most of the old rubber gasket was brittle and broken. Popped in the new gasket from outside, lubricating the opening with a little Griot's Speed Shine and gently helping to push the gasket to place with a small screw driver, being very careful not to mar the paint by putting an old credit card between the screw driver and paint. Took all of about 10-15 minutes, if I recall.
Dan
'03 325i OrBlu
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
Old 04-04-2005, 10:41 AM
cs1221
Thanks! I appreciate the info. Just ordered the part, and I'll give it a go...
Similar Threads
Sirius retrofit finished... x5Monkey® X5 E53 (1999 - 2006) 33 11-25-2004 04:14 AM
Sirius Install - Antenna Detail kneebiters General BMW Questions 4 09-02-2003 05:24 PM
LONG --- Another Happy Sticky Pedal Fix Customer!!!! The BoatMan 3 Series & 4 Series 20 08-08-2003 03:51 PM
E46 cell phone antenna leejak 3 Series & 4 Series 9 07-28-2003 08:13 PM
Need help with antenna wire @ HU wlee69 E36/7 Z3 (1996-2002) 2 06-09-2002 09:13 AM
