Old 04-04-2005, 01:22 PM
shaftdrive's Avatar
shaftdrive shaftdrive is offline
Matching beemer & bimmer
Mein Auto: 1999 K1200 & 2001 525
Does your 5-series driver-side armrest fit your arm?
My 5-series driver-side armrest seems too short for a normal human.
The (much longer) passenger-side armrest seems to fit better.
Does your driver-side armrest fit the length of your arm comfortably?
ID:	47844   Click image for larger version
Old 04-04-2005, 01:29 PM
shaftdrive's Avatar
I never knew I had sensitive elbows until now
The too-short E39 driver-side armrest forces my arm up to the door sill.
But, my elbow hurts on this too-high too-hard driver-side door sill.
Do you find the door sill to be a comfortable alternative to the driver-side arm rest?
Old 04-04-2005, 01:41 PM
Robert A Robert A is offline
Mein Auto: BMW 535d
I also had the same problem, and reported it to my dealer while my car was under warranty. The dealer said "they all do that" so I pursued it with the factory rep who decided to give me a door from the E60. Now it's much better, but I have a problem with wind and water leaks. Oh well!
Robert A
BMWCCA Member
Current
2014 535d, M Sport, Space Gray/Mocha Nappa
Prior
2007 530i, White/Black, 6MT
2001 530i, Orient Blue/Beige, 5MT
1994 325is, White/Black 5MT
1984 325e, White/Black 5MT
1983 318i, Delphin/Beige 4MT
Old 04-04-2005, 01:58 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Jeff R.
Old 04-04-2005, 02:53 PM
GJR's Avatar
GJR GJR is offline
Mein Auto: 2003 530i
I have a problem with this as well. At least it should have been padded where the elbow rests on the armrest while your left hand is on the wheel. Take a look at this link- they offer an add-on leather cushion for the Z3s and Z4s. I'm sure they could custom-make one for the E39.
Leather Z
Old 04-04-2005, 03:01 PM
FireWalker's Avatar
FireWalker FireWalker is offline
Mein Auto: 2002 530i sport
Now, be nice... I said, be nah ice!
"...Those who would give up their freedom in exchange for security, deserve neither!..."
Old 04-04-2005, 04:10 PM
shaftdrive's Avatar
The E60 doors are much better, but I have a problem with wind and water leaks!
I don't understand, Robert A?
Is your astute suggestion the result of your extensive tests or of your comprehensive research? (e.g., http://www.honestjohn.co.uk/road_tests/?id=106):
"The E39 has low wind noise, but the E60 is almost eerie."
When we follow this thoughtful advice, our results should be "almost eerie."
Old 04-04-2005, 11:57 PM
redbeemer redbeemer is offline
Mein Auto: 525i
Just put Robert into your killfile & forget about him.
Nobody has ever heard him saying anything intelligent.
Old 04-05-2005, 07:09 AM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
I would agree to an even shorter arm rest if it meant the PDL button would reside along side the PW buttons.
-Mark
I Timothy 2:1-2
Old 04-05-2005, 07:29 AM
BMW528i_Bilal BMW528i_Bilal is offline
Mein Auto: 2000 BMW 528 i, BMW 318i
Another comfort issue !
Old 04-05-2005, 04:04 PM
shaftdrive's Avatar
Good point!
Since the BMW driver-side armrest does not appear to be usable, we may as well enjoy the utility of a properly-located door-mounted power door lock alongside the (nicely positioned) power window buttons.
Interestingly, a friend with the '98 528 says his badly placed power center-console door lock button only unlocks the doors when his key is in the ignition (engine running?). Specifically, his console-mounted PDL button doesn't cause the doors to lock when the car moves a few hundred feet. My center-mounted PDL button at least does something in that it seems to tell the doors to lock after a short distance of driving. Still, as you noted, when I exit my vehicle and then try to open the (now locked) rear doors, I have to either reach into my pants pocket to locate the key to unlock those doors again or dive halfway back into the car to locate the poorly positioned PDL button (as you noted).
Old 04-05-2005, 05:36 PM
Mein Auto: BMW 535d
Chill! I was just joking.
Robert A
BMWCCA Member
Current
Prior
Old 04-05-2005, 05:37 PM
an audience of One
This can be programmed at the dealer
Yup, this definitely bugs the crap outa me.
-Mark
I Timothy 2:1-2
Old 04-05-2005, 11:05 PM
Mein Auto: 525i
I was just joking.
Me too.
Similar Threads
A purist review of SMG II nate General BMW Questions 30 03-25-2013 05:47 PM
BMW ConnectedDrive: ChrisTO General BMW Questions 12 11-08-2005 06:41 AM
SMG wheel fit 3 series? ak330i 3 Series & 4 Series 21 02-03-2003 07:47 PM
Glueing the cover of the driver side mirror? bimmee 3 Series & 4 Series 0 10-26-2002 10:33 AM
