E36 (1991 - 1999)
Old 04-08-2005, 04:16 AM
fredo328 fredo328 is offline
Mein Auto: '98 328
Can the ATC ABS sensitivity be adjusted?
My ABS kicks in sometimes when I brake on a rough road and the other day right after the abs kicked in at a light I then tried accelerating and the ATC kicked in. Its only happened this one time about a week ago and I've put some miles on the car since. Bud of mine said that my wheel sensor might have had some dust or dirt on it which caused this to happen. I was thinking that maybe the "sensitivity" either on the throttle body or wheel sensor needs to be adjusted-is this possible?
Old 04-08-2005, 06:34 AM
ImperialDuckM3 ImperialDuckM3 is offline
Mein Auto: E36's
What's a ATC? I know ASC, which is your traction control. ABS is your Anti-Brake System, which comes on when it sense you losing control of the car. The ASC and ABS work together to save you from falling down the cliff, when you tried to race a P on the twisties
There's nothing you can do to "adjust" it. Just try to slow down,when you near the "rough" roads.
Similar Threads
ABS light on - then off - at 1000 miles?!? sun 3 Series / 4 Series 4 04-13-2004 11:45 AM
Yellow Warning on Dash: DSC, Brake & ABS crete 5 Series 16 03-29-2004 09:12 PM
Scary Sliding Waverz General BMW 27 01-14-2004 08:54 AM
Need suggestions on how to get great abs!!! Jimmy325 Off-Topic 42 06-26-2003 01:27 AM
ABS Off?? rwg 3 Series / 4 Series 17 09-17-2002 11:26 AM
