Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 03-26-2005, 01:48 PM
jamie bayley jamie bayley is offline
Mein Auto: BMW 318i E30
Smile M40 BMW 318i problem
Hello,
I have this problem any help welcome.
When driving ,occasionally the engine will not accelerate, (it runs perfectly at idle only). Switching the ignition switch off and then on immediately fixes the problem. The engine is also slow to start,hot or cold
I have replaced the Fuel pump relays,
the distributor cap,the rotor arm and thought I had the problem beat ,but its back!
Also the fault is immediately cured by simply pulling and resetting the fuel pump fuse.
The fuel pump was replaced 6 months ago.
Could it be the pressure regulator or filter?
Old 04-08-2005, 06:23 PM
SWISS's Avatar
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Talking
Originally Posted by jamie bayley
Hello,
try your t.p.s sounds like it(throttle position sensor or mass air flow sens.)then agian
its missing two cylinders! try a 325i im sure that will fix your accelleration prob
Similar Threads
Top BMW dealers in the country Mathew General BMW 37 07-06-2009 06:58 PM
1998 M3 = 540i = 740i = 20K rumratt General BMW 36 01-12-2007 06:26 PM
Go w/Lemon Law or continue to wait? pylt Dealer Feedback / Vehicle Problems 5 11-17-2004 07:54 AM
Bangle gone jeff330i General BMW 15 02-13-2004 08:48 PM
BMW Model Year 2004 Changes (BMW NA) WAM General BMW 1 08-06-2003 11:13 AM
