E30 (1982 - 1993)
suspension, brakes + project
hey guys,
finally ready to dive into this project. have all needed work done and parts pressed in. The new rear bearings are in as well as the S/F Bushings, welded reinforments for rear sway bar to trailing arm mounting point. any advise ? thanks. Frank ![]()
Awesome man! BahnBaum has A LOT of E30 suspension experience. I believe he has a stickied thread at Bimmerforums.com.
Good Luck! |
thnaks misterlance,
i'll look up BahnBaum posts. this is what i did so far... - installed frame brake lines, - rear sway bar, - trailing arms into sub-frame, - 3 jacks, raise whole assambly, wiggle in and attach old shocks to trailing arms., then you can pullback and forth on subframe assambly, line i up with S/F screws, dont forget washer between bushing and frame. ![]() ![]() ![]() ![]()
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Porterfield R4-S bedding question??? | Zeegar | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 1 | 08-02-2004 01:38 PM |
| '01& up 530 brakes same as 540 brakes? | ///-Power | 5 Series | 8 | 05-15-2004 07:54 PM |
| i've had my brakes checked out twice now, is it just me? (Please HELP) | drpahjee | 3 Series / 4 Series | 1 | 07-23-2003 11:05 AM |
