E30 (1982 - 1993)
Old 04-02-2005, 01:45 AM
dannyb86 dannyb86 is offline
Mein Auto: 87 325es
Exclamation power steering rack leak
im looking to see if anyone can help me find out if there is any kind of rebuild kit for the power steering rack on a 87 325es. i also am looking to see if there is any kind of repair manual or website that has procedures for doing it or if anyone has any knowledge about doing this or would i be better off buying a remanufactured one. thanks. Daniel
Old 04-03-2005, 12:39 PM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Cool i got the same prob
i found a place that sells arebuild kit for around 40 bucks (www.bmpdesign.com call them and askfor anthony ext 305) but i need install help i really think this might be a tricky thing to do, let me know if u get install info christo325i
Old 04-05-2005, 02:42 PM
Mein Auto: 87 325es
i took the steering rack out today. it is kinda complicated took about 4 hours that probably bc i didnt really know what i was doing. i have already got the kit and will be tearing it down and attempting to rebuild it. it shouldnt be any problem bc i know the seal was blown.
Old 04-08-2005, 09:09 AM
9x16's Avatar
9x16 9x16 is offline
Mein Auto: 89 BMW 325i (4 door)
I recommend you change the high /low pressure hoses too.
Old 04-19-2005, 10:05 PM
Mein Auto: 87 325es
power steering replacement
after doing the rebuild i highly recommend just buying a rebuilt power steering rack from the start unless you have the tool to take loose and re-tighten the locking collar nut (picture attached) as in my case i got the whole rebuild done and just couldnt get the nut tight enough before destroying it. if you have the single piece power steering rack by all means attempt it its not hard just take your time. Figures that i would have one of the racks thats different than everybodys else as always seems the case for me. good luck if you are planning on rebuilding your rack and if you have any questions just postem i check here often. Daniel
ID:	48661   Click image for larger version
ID:	48662   Click image for larger version
Similar Threads
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW Questions 7 07-19-2006 04:52 PM
can having a low supply of power steering fluid make the steering feel lighter? ajjour 3 Series & 4 Series 1 09-27-2002 04:51 PM
Perfect steering at last (long) PG 3 Series & 4 Series 25 05-15-2002 12:01 PM
