Hard time getting valve cover off - Bimmerfest - BMW Forums
Old 11-26-2017, 05:48 AM
heavyritefoot heavyritefoot is offline
Mein Auto: ford f150 ecoboost, fusio
Like the title says. Removed all the bolts but just can't peel the cover off. Previous owner did the job also and it looks like the mechanic went crazy with rvt sealant. Seems like it's hard to lift up from the center where the spark plug gaskets are. Just don't want to crack the valve cover and add extra money to this job. Any ideas?
Sent from my SM-G955W using Tapatalk
Old 11-26-2017, 07:41 AM
Davein Davein is offline
Mein Auto: 328ix
Get a thin blade under the edge and slowly and carefully cut it loose until will come loose the rest of the way. Work around it being careful not to nick up the mating surfaces.
Old 11-26-2017, 09:37 AM
Cancar123 Cancar123 is offline
Mein Auto: Bmw f30
a lot times people forget the 10mm bolt in the center under vvt motor because sometimes it be covered in oil. Double check all the bolts are loose then insert a flat head betweeen valve cover and block and just keep wiggling it around
Old 11-26-2017, 09:52 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is online now
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Originally Posted by heavyritefoot View Post
....looks like the mechanic went crazy with rvt sealant.
328i?
Old 11-26-2017, 10:41 AM
Thanks got the 10mm loose just hanging in the cover. It's a 2008 328xi with 160000 kilometers on it. My dad suggested tapping with a rubber malet. So he's coming over so I can pry and he works the rubber malet. The worst case scenario is I buy a new valve cover in the process.
Old 11-26-2017, 11:51 AM
Forget to mention where the 3 gaskets are for the spark plugs are. That where the cover doesn't want to lift from. I think the mechanic used a whole tube of rvt in that area.
Old 11-26-2017, 03:42 PM
Steve111 Steve111 is online now
Mein Auto: 07 328xi
This "mechanic" sounds like a complete hack. He should not be using rtv on this at all.
Old 11-26-2017, 03:58 PM
AlphaBetaX5's Avatar
AlphaBetaX5 AlphaBetaX5 is online now
Mein Auto: X5 e70 3.0i
+1
and also make sure you unbolt the two bolts, one near plug#1 and the other near plug#6. You need a deep socket. (if your engine is N52)
Blade works, but patience is what you need. Try using a flat head screw driver, and slowly and gently lift up the cover. Start from the front end. It is far easier than what it looks.
I just did this job a week ago.
So some people don't use RTV, and they are fine. using a very small amount of RTV is not bad at all. It helps you during the gasket installation by keeping the gasket in place.
Especially the small spark plug gaskets. you do NOT want to perform this job AGAIN!!! I recommend using a 2 mm bead RTV on the new gasket. I did it the first time, It came of very easily and never had any leak.
I did it again on the second time I removed the cover for sensor replacement.
Good luck.
Old 11-26-2017, 05:58 PM
Finally got it off. Forgot a 10mm bolt in between the spark plugs.
Old 11-26-2017, 06:01 PM
Bought all 3 original bmw gaskets for the job. Eccentric shaft and valvetronic sensor and valve cover gasket.
Old 11-26-2017, 07:22 PM
Mein Auto: 07 328xi
All that for a forgotten bolt
Old 11-26-2017, 08:14 PM
Mein Auto: Bmw f30
Ya'll welcome
Old 11-26-2017, 08:22 PM
Mein Auto: Bmw f30
Wow soo much rtv make sure to not reuse bolts they are aluminum could cause oil leak
Old 11-27-2017, 06:28 AM
Reregistered User
From pics, already there. As a PM - 328i valve covers go bad - I'd replace it.
Now the clean-up. Do NOT get RTV bits in your engine!
Old 11-27-2017, 08:33 AM
gbalthrop gbalthrop is offline
Mein Auto: 2007 328xi
I thought his 2008 328xi (N52KP) had steel Valve Cover bolts which are reusable? Bentley VCG Install procedure is attached. Since you have NO metal/metal seams (such as timing cover), RTV only creates problems, preventing gasket from fitting snugly into grooves in cover. Clean (remove ALL RTV) thoroughly and make sure new gaskets seat snugly in cover grooves.
George
Old 11-27-2017, 08:37 AM
Attachment Reference in prior post (Bentley VCG Install Procedure).
George
Name:	VCG Install.jpg
Old 12-06-2017, 02:04 PM
NMN14 NMN14 is offline
Mein Auto: Z3
I used this video for replacing the valve cover gasket. He also talks about how to get it out when stuck. The part of the sealant is also nice. He talks about on how much sealant should be on the gasket and where.
