engine overheating at idle - cooling fan - Bimmerfest - BMW Forums
Old 12-01-2017, 10:36 AM
koreanknife koreanknife is offline
Mein Auto: 2011 328xi
My 2011 328xi N51 SULEV overheats when I idle for a while, like in traffic or very slow drive-through. I thought that it may be the thermostat or water pump. I took it into a shop to have it diagnosed, and it turns out that the radiator cooling fan does not kick on. It's getting power from the connector. I noticed I haven't heard it turn on in a while...
No code faults were given.
Could it be the cooling fan switch? I hope so, as it's only $13, and ordered one. I will update if this makes the fan turn back on.
If the cooling fan needs to be replaced, which fan do I need to get for my N51 engine? They seem to be engine specific, but I am having trouble determining if I need to 400W or the 600W. If someone can point me to a good deal for one, I would really appreciate it.
2011 328xi
Old 12-01-2017, 10:51 AM
e92_dub e92_dub is offline
Mein Auto: 2011 335i
are you certain it's not the water pump? I had the same issue with my car (335i N55) and I also didn't get any codes but it ended up being the water pump.
Sent from my Pixel 2 using Bimmerfest mobile app
Old 12-01-2017, 01:03 PM
AlphaBetaX5's Avatar
AlphaBetaX5 AlphaBetaX5 is offline
Mein Auto: X5 e70 3.0i
Yours is 600 w.
Pn# 17427547305
According to realoem.com
Sent from my iPhone using Tapatalk
Old 12-01-2017, 08:44 PM
I'm not 100% sure it's not the water pump, but just trying to work at the most obvious problems first. Since the fan is not cycling on when commanded to, there is an obvious problem there. I can get the water pump when activated to move the coolant using the bleeding procedure.
Does anyone know if the fan doesn't turn on during long periods of idling, is the water pump enough by itself to cool down the temperature?
2011 328xi
Old 12-01-2017, 08:53 PM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
fan should come on if your car is overheating, one thing i read previously is that the AC should make it come on regardless of the cooling fluid temperature.
2011 328i X-Drive Sedan N51 AT; Black / Black.
Premium, Value, Hi-Fi stereo, etc.
Old 12-06-2017, 07:07 PM
Got my radiator fan replaced. fixed the overheating issue. mechanic said that there is a larger than normal lag between the top and bottom radiator hose temps and to keep an eye on the thermostat. feels good to have the car running normal temps again.
2011 328xi
