HELP!Bad vibration after 1300RPM on E90 320D M47 engine - Bimmerfest - BMW Forums
Old 12-07-2017, 10:18 AM
alex_pe314 alex_pe314 is offline
Mein Auto: E90 320D M47 NO DPF 164HP
Hello all,
Really sorry if this thread already exist somewhere, but I wasn't able to find something like my problem.
2 weeks ago I bought a 2006 E90 320d from an auction , and the moment I got in the car and started driving this bad vibration was noticeable inside the cabin . The vibration only starts after 1300 RPM and it doesn't matter if the car is standing still or driving, happens in any gear . The car only has 86k and it's in a very good condition , fact that made me bought it. I need to add that the vibration gets bad when the car heats up. By now I've changed the following: glow plugs-blanked flaps ; clutch and flywheel ; engine mounts ; ,tensioner pulley , idler and belts , and today I've just had the crankshaft pulley changed .
None of these helped , vibration is still there and it drives me crazy .I've looked a lot on youtube and there is only 1 guy that had the same problem and for some fuel lines where loose , but in my case I've looked twice, noting is loose , everything is where it supposed to be . The last thing I will do now is to change the gear box mounts, but anything else...I'm running out of ideas ,and money and afraid that the engine will blow up The garage that did the clucth , flywheel and crankshaft said that they couldn't see anything bad and maybe this is just how the car behaves , but this is not my first E90 320d and that one I had before did had any vibration and was smooth and had more mileage than this one...
If anyone would be able to help with an advice , it would be really helpful .
Thank you.
