Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E46 M3 (2001-2006)
E46 M3 (2001-2006)
Old 04-26-2005, 09:50 PM
m3fest m3fest is offline
Mein Auto: M3 SMG Convertible
Recommended Cabrio Tire Pressure
I am looking for recommendations for the ideal tire pressure for VERY aggressive driving.
Here are my specifics...
I will set the pressure first thing in the morning BEFORE driving at all and the outside temp is about 65 degrees.
I have the 19" factory rims with the Conti tires
The rear tires have about 10% tread left and the fronts 30% (I am waiting for a set of back-ordered PS2's to come in).
NO rain driving
NO passengers
Outside So. CA temps right now are around 70 to 80 degrees
I am looking for maximum cornering ability and minimized under-steer.
Thanks for the help!!!
Nick
M3 SMG Convertible
Tit Silver/Blk Top/Gray Leather/Alum Trim
19's, Heated Seats, Xenons, HK Prem Sound
Old 04-26-2005, 11:41 PM
dawgbone dawgbone is offline
Mein Auto: 05 BMW M3
NO rain driving
NO passengers
Weird question...
As far as the stock Contis, as well as stock suspension setup...Look inside the driver's side door..BUT, with 10% tread(rears)...I would deflate them to 10psi less than what's on the sticker..Or replace them quickly(they go fast, once signs of good wear)...As far as the fronts, swap left from right..
If the car is stock on all suspension components...It's a good idea to keep the understeer..The car has been tried and tested for those tires and tow/camber...Despite the overwhelming tilt/lean, the car actually will pull nicely out of corners with a stock setup..But you need to specify, not temps of SoCal, but what you are trying to do with the car...You might need something more than tire PSI....$$$
Old 04-27-2005, 01:44 AM
Thank you!!!
I may have been exaggerating the wear...I only have 8,000 miles on the car so I know I could get at least another 2 to 3 thousand miles from the rears and even more from the fronts.
I am certainly aware of the OEM recommendations 33 F & 35 R but I am also aware that whatever they are recommending is based on a pressure that is a balance between grip and comfort for people that use the car as a daily driver.
However, based on the fact that I am NOT interested in comfort and strictly use the car for aggressive driving under the conditions I mentioned above, and NOT as a daily driver...I was really interested in what pressure would give me the best grip with the stock suspension, tires and wheels.
I guess even more specifically, I currently run 36 F & 38 R and have heard that if I were to run 38 or even 40 all around it would improve the cornering and reduce the under-steer further?
I was also told that the tires are directional and should NOT be switched from side to side, as a matter of fact I'm pretty sure the sidewall has an arrow identifying the direction the tires should be rotating? And even if I could rotate them I don't see any benefit since the wear on all 4 has been EXTREMELY even and consistent.
Nick
M3 SMG Convertible
Old 04-27-2005, 03:28 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
I would NEVER inflate the tires to less than factory specs. You are asking for a blown tire, at speed.
For street driving, raise the pressures. Most tires need pressures in the mid 40s or higher to maximize performance. To tune, you need to reduce rear grip to balance lack of front grip.
As a starting point, for most drivers I suggest 2 - 4 psi more all around, then another 2 - 4 psi or so in the front to reduce understeer. So rear goes from 35 factory to 37 - 39. Front goes from 33 factory to 37 - 41. Then play with pressures.
Or just pump them all up to the maximum pressure on the sidewall, then lower rear to reduce understeer. But with stock tire sizes, you will not see much reduction in understeer. So just plan on 265s all around when you replace the tires.
And next time, if you are looking for maximum performance, get a Coupe. Lighter and more torsionally stiff
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Similar Threads
225/45zr17 tire pressure HW Tire Rack's Tires, Wheels, Brakes & Suspension 10 04-06-2008 03:10 PM
checking tire pressure...a cautionary tale car_for_mom Tire Rack's Tires, Wheels, Brakes & Suspension 21 11-12-2005 07:24 AM
Winter tire pressure question kioneo Tire Rack's Tires, Wheels, Brakes & Suspension 1 11-29-2004 06:11 AM
Correct tire pressure dinanti 3 Series & 4 Series 2 01-27-2003 04:51 PM
325Ci Coupe tire pressure ques. - DJ not right Scotes 3 Series & 4 Series 2 03-01-2002 03:14 PM
