CA draining battery while off? - Bimmerfest - BMW Forums
Old 12-07-2017, 12:19 PM
tooyoung00 tooyoung00 is offline
Mein Auto: 435i
So I was sitting in my car with Engine and all lights/ everything turned off for about an hour. When I tried to turn on the engine, it wouldn't start. Luckily I was able get a jump from a friend and I was good to go. The next day, same thing happened. So another day after that thinking that it might be CA, I removed the battery on the fob and sat in the car for about an hour as usual. It started without any problem.
I checked the fuses and everything was working. Anyone experienced anything like this? I been driving without CA and its been fine but it's a lot hassle. Thinking about taking it in the dealers this week but wanted to check with people from here.
Thanks in advance
Old 12-07-2017, 12:34 PM
acoste's Avatar
acoste acoste is offline
Mein Auto: 2010 550i MT
Are you doing a lot of short trips so the battery doesn't have time to get recharged?
If a CA key is near the car it keeps some modules awake which might drain the battery.
some thoughts:
- your battery isn't fully charged for whatever reason. short trips? bad alternator? bad battery?
- car off, but modules awake for 1 hour needs ~20Ah charge. Your battery capacity is around 100Ah. If the state of charge of the battery is around 40% when stopping the engine, this no-start issue could easily happen.
- temporarily you could put the key in a fully closed metal case when sitting in the car.
2010 BMW 550i MT
2003 BMW 325i @207k and counting
1998 BMW 528i MT @ 231k //sold
1997 Saab 9000 //sold
Old 12-07-2017, 03:50 PM
jjrandorin jjrandorin is offline
Mein Auto: 435 Grand Coupe MSport
My thought is the same as acoste. You likely have a battery problem. If you take a lot of short trips, AND park in a garage and dont lock the car when you get out, its likely your battery is never getting fully charged. You either have a bad battery, or a low battery, probably. Get yourself a battery charger ( make sure you get one that works for your car which likely has an AGM battery).
2016 435 Grand Coupe Estoril Blue MSport |Hex. EB Trim-Blk. Dakota | MSoort | Technology | Drivers Asst. | Drivers Assist+|Lighting |Track Pack W/ 442 Wheels |Heated Frnt Seats | Smartphone Integration | HK Stereo (His)
2016 X5 XDrive35d Space Grey |Blk Dakota W/ Fineline Oak | MSport | Lighting Pack | Premium Pack | Drivers Assist | Drivers Assist + | ACC W Stop N Go | 20" Wheels| Smartphone Integration | Multi Contour Seats | HK Stereo (hers)
BMW CCA #477341
