E46 (1999 - 2006)
Old 05-04-2005, 06:16 PM
cparth08 cparth08 is offline
Mein Auto: 328i
Door to gas cap
when i push on the door to get to the gas cap, it should pop open but won't. can't pull it open either. any ideas please?
Old 05-04-2005, 06:18 PM
wongtomm wongtomm is offline
Mein Auto: 2005 White 330i
unlock the doors
Old 05-04-2005, 06:23 PM
Mein Auto: 328i
did that, didn't work
Old 05-04-2005, 06:29 PM
MMME30W MMME30W is offline
Mein Auto: .
Well...would need some more info before offering suggestions.
When was it last working?
Anything happen recently (accident, small children, ...) to the car?
Is the car reasonably clean i.e. no mud, snow, ice on or around the gas door?
Possible to "jiggle" the door to get something in behind it, maybe like a flexible plastic spoon or similar?
Old 05-04-2005, 06:32 PM
Mein Auto: 328i
was last working a week ago. no accidents. had it in for inspection 2 days ago, clean as new. i put a credit card and a key behind and messed around, no luck.
Old 05-04-2005, 06:47 PM
Mein Auto: .
Hmm...
Not sure if your car is like mine (03 E46) but I had a quick look just now:
- when the car is unlocked, the gas cap door is not held in place except by the spring of the door
- when the car is locked, there is a deadbolt which engages in a slot in the lower rear of the door
- on mine I can feel the deadbolt engaging and disengaging the slot when the car is locked and unlocked
Can you lock/unlock several times and see if the solenoid is able to be felt engaging / disengaging in the slot? If not, the fault is there, i.e. possibilities are 1) fuse to solenoid circuit 2) solenoid has failed 3) wiring has failed. Without a schematic hard to tell where to start.
I don't know if it would be possible to remove any of the interior of the trunk near the gas cap to see what's going on?
My user's manual contains the following statement:
"If an electrical malfunction occurs, you can unlock the fuel filler door manually:
1) undo the trim panel on the right side of the luggage compartment
2) pull the knob with the fuel pump symbol.
Good luck...
Old 05-04-2005, 08:11 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i
Originally Posted by wingspan
Hmm...
- when the car is unlocked, the gas cap door is not held in place except by the spring of the door...
On my '05 330i, the gas cap door also uses a "click type" latch even when the doors are unlocked. To open the door, I have to press slightly inward to release the catch mechanism. Same with closing. Again, this scenario is independent of the lock plunger which engages when you lock the doors. If yours has this type of latch, maybe the release mechanism is stuck. I'm not sure the emergency release pull in the trunk works on that part or just the plunger part if it's stuck...
BMW-CCA
Bimmerfest Supporting Member
2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Old 05-04-2005, 08:14 PM
obmd1's Avatar
obmd1 obmd1 is online now
only one screen name
Send a message via AIM to obmd1
Mein Auto: Toyota 4runner
as I recall there is a means by which the door can be unlatched in case of a failure of the solenoid.. .perhaps behind the carpet in the trunk? It's in the manual...Sounds like that is where the problem is if unlocking your doors doesn't work...
Hope this helps...
Old 05-05-2005, 12:16 PM
Salvator's Avatar
Salvator Salvator is offline
Livin' like Larry!
Mein Auto: 2007 328XiT; 2008 328 CiC
My car has a little green knob on the trunk that you can pull, supposedly will release the gas door lock... good luck!
Old 05-06-2005, 03:46 PM
Mein Auto: .
Agreed, but on mine you can open the flap if the car is unlocked by just sticking a finger nail under and lifting. There is no "catch" on the "clicker". But I see what you mean...
Old 05-06-2005, 04:13 PM
allaboutme allaboutme is offline
Mein Auto: 3x330,AMV8,996GT2
just to be sure you might have to have all the doors unlocked to be able to push open the gas door... but that might not be your problem.
Old 05-07-2005, 01:47 PM
markl53's Avatar
You're right, I just happened to check this when I filled up earlier today. The "clicker" does not hold the door captive so that can't cause his problem. I haven't figured out if the purpose of the thing is just to move the door outward for easy opening, or if it's magnetic as well to hold the door when pressed in.
BMW-CCA
Similar Threads
Gas cap is stuck vbmw E46 (1999 - 2006) 0 03-08-2005 04:26 PM
Gas Cap Light on mswaz 3 Series / 4 Series 6 04-23-2004 06:52 PM
Hmm, I wonder if I have a busted gas cap Kaz 3 Series / 4 Series 0 06-18-2003 07:20 AM
M roadster locking gas cap? TxnBluDvl E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 4 05-14-2003 04:59 AM
