5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
Battery Disconnect Switches
If you leave your 530i parked for extended periods, the battery will be drained by the alarm and other systems.
I have learned that some cars are fitted with battery disconnect switches. Here is a collection of links to these products: http://www.odysseybatteries.com/hella.htm http://www.flamingriver.com/switches3.htm http://www.moroso.com/catalog/catego...?CatCode=42225 http://www.mgcars.org.uk/electrical/body_switch.html The last link is a how-to article. It also shows a switch (available from JC Whitney) that mounts directly to the battery terminal. The "most engineered" system seems to be the switch from Flaming River. This one has a key you can take with you. Anyone tried any of these systems? I guess the first puzzle would be, where to mount the switch? Welcome your thoughts on this. Regards, Michael |
Product report
Flaming River offers two switches. I purchased the one with the key, but if I were to do it again, I would just use the one with the T-handle. It is a sealed unit, which is a good feature since sparking is a concern.
The switch mounts behind the battery, very neatly. It has solved the problem of the burglar alarm running down the battery. I now keep a flashlight in the trunk to make it easier to find and turn the switch in the dark. Be sure to disarm the burglar alarm before using the kill switch to turn the battery off. Will post a photo when I get a chance. Very happy with the product, and with the neatness of the mounting. |
Excellent! Thanks, Michael!
Does anyone know if you disconnect the battery, if when reconnected and started, there is a "re-learn" process for the ECU on a E39? I ask, because that is definitely the case with some cars I have owned. Typically you restart without touching the gas pedal (as normal), and then don't touch any controls or gas pedal for anywhere from several seconds to several minutes (usually outlined in the manual). I have not seen such warnings in the owner's manual for my 540.
Dave |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| HELP! is a battery disconnect while vehicle running OK? | ezekiel2517 | 3 Series / 4 Series | 13 | 07-08-2004 06:22 PM |
| Disconnect battery when removing door panel? | ldn | Do-It-Yourself H.Q. | 2 | 07-01-2004 02:14 PM |
| Battery disconnect question | Chendol | 3 Series / 4 Series | 5 | 12-07-2003 03:52 PM |
| Safety notice I just received at work. | Hunter | Do-It-Yourself H.Q. | 0 | 11-19-2002 07:52 AM |
| If I disconnect my battery to install the M3 steering wheel... | Damon | General BMW | 6 | 01-04-2002 09:38 PM |
