E46 M3 (2001-2006)
#51
Actually, Military Sales offices in Germany are affiliated with host nation dealerships, so you can see some of the cars, and speak with a competent sales rep, etc.
As for the Comp Package, I'll leave that one alone. I didn't feel it warranted waiting an extra 4-5 months for my car, but I did drop $2,100 for Individual paint, so what do I know? ![]() Chief |
#52
t do anything, except start cracks. And many race teams, as well as people who track rotors with holes in them, find them cracking between holes. You under estimate the potential of a stock E46 M3. You are talking about a car that one street tires is good for 145 at the Glen and 135 at VIR (two place on the full track), and over 140 at Summit Point, and weighs some 3400 pounds with people on board. Add in R-comp tires and any form of suspension upgrade, and you are talking even higher speeds into braking zones. The car is bloddy FAST, and bloody HEAVY. LOTS of brake energy. SS brakes lines don't do anything for dealing with heat. They do enhance pedal feel by eliminating one more area of flex in the system.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
#53
2002 E46 M3 Dinan S3-R |
#54
Only downside of slotting is less pad life. The slots act as a lathe to grind the pads off a bit quicker. The idea on the race track is that they scrape off any glazing that might occur.
Also if there is any pad outgassing, the slots will carry that away also. But not a problem with modern pads, except BRAND new ones. Once they are bedded no problem. For the street, a MUCH better choice than drilled, but the best overall is really just normal rotors. So, I wouldn't say you made a big mistake, but maybe a very small one. ![]() Ferodo was a very big name in pads, but not heard from much lately. But if they are working well, then they are working well. The things I look for in pads is good initial bite, linear feel, low dust (for street) and low noise (also for street). And pretty much in that order.
#55
#56
I'm not an M3 owner (yet - hopefully this summer) but I was reading this thread and wanted to comment on the cross drilled rotors. Apparently many people had problems with cracking when the holes were actually DRILLED into the rotors therefore weakening the structure. The better "cross-drilled" rotors from what I am told are actually forged with the holes in them making one solid structure less prone to metal fatigue.
I was looking at the PDF file on the competition package and they said that the cross-drilled may make more noise than the regular rotors - is that the case? I personally think they look cool (and are almost 1" bigger) but I'm a big fan of symmetry. If they were cross-drilled in both the front AND the back I would like it better. The other concern of mine is that performance brakes are usually meant for the track and do not necessarily perform the same way. My friend put performance pads and power slot rotors on his car and stated that they did not really start grabbing until they heated up and almost caused an accident when pulling out of a parking spot. Not to say that the BMW brakes would be the same as those. |
#57
"The drilled rotor so common on the Porsche 930 turbo is NOT really drilled at all. It is a CAST hole. Porsche did this to help minimize the effects a hole has in creating a stress riser in the surface of the brake rotor. A drilled hole goes directly through and interrupts the grain structure of the metal. Where as a cast hole has the grain structure formed around it in an uninterrupted flow. All holes in a brake rotor will eventually show signs of stress cracking. A drilled hole will crack much sooner than a cast one" Quote:
"The cross-drilled, compound front rotors have been increased to 13.6" (up from 12.8"). " I do not see any mention of the rear rotors being cross-drilled as well - is BMW incorrect? Quote:
"The M3’s already powerful brakes have been improved to meet the demands of repetitive hard braking experienced on the track."
#59
#62
I know it's not "track" ready but it's no furhter off then the non-ZCP. ![]() No worse then Mits advertising the rally capabilities of the EVO and then refusing all warranty claims because of such use. |
#63
Besides the cross-drilling, the ZCP rotors are also floating rotors with aluminum hats. The hats reduce weight, but are prone to cracking as well, and must be checked periodically. I believe that because of liability fears of hat fatigue, the Euro M3 brakes weren't offered in the US initially. The floating rotor accommodates heat expansion radially so the braking surface stays planar instead of bowed.
--Andre |
#64
Also realize there are performance pads and performance pads.
There are street performance pads that work fine cold. Maybe not quite as well as stock BMW pads, but still fine for street use. Less dust many itme, low noise, but better high temperature performance. Then there are track biased performance pads. Most of these take a good bit of heat to work. NOT good for street use, since you often have cold pads with virtually no bite. Also these tend to make a lot of noise and a LOT of dust, which may be corrosive adn ruin wheels and paint jobs if not washed off promptly. There are a few pads with reasonble cold bite that hold up on the track. But they are few. The rotors had nothing to do with it, he picked the wrong pads.
#65
#66
there is so much talk about wheels and brakes. Both are essentially parts bin items that any M3 can update down the road for a price.
the steering rack is the only piece that can't be bought/fitted later because of the sensors/electronics/DME's that need to be updated. this might be the best reason to get the package, but many keep saying that it is only a marginal difference. thoughts?
The five D’s of dodgeball: dodge, duck, dip, dive, and dodge. -2006 Z4 M Roadster (Sapphire Black/imola red)...12/9/2006 -2006 M3 ZCP Interlagos blue/black via PCD 11/29/2005 -2004 330i ZHP Imola red/black alcantara CPO 1/2008 -1999 Audi A4 1.8tQ (Jaspis Green/Black) -1986 325es (Zinnoberot red/Pearl) |
#67
I really have to go drive one...although everything I've read from people who have actually owned/driven both says that the difference is negligible. |
#68
yeah, it seems odd that the one thing the car needs to improve, $4000 doesn't seem to do much for.
anybody with a ZCP M3 able to tell a difference? and boy would I be pissed if they added it to the base model this year!!
#69
We can do that. When are we stripping your car out?
#71
Perhaps someone who has the ZHP M3 knows the answer? |
#72
Alex |
#74
Yeah, and BMWUSA.com says the ZCP package has forged wheels and 8.5 inch fronts. BOTH are wrong.
But those wheels DO look nice. Are the offsets th same as stock? I wonder if you can run rears all around?
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| What to look for in buying a 01/02 M3 | jluo458 | M Series | 4 | 09-08-2004 04:41 PM |
| Buying an E30 M3 | Polle325 | M Series | 1 | 03-20-2004 07:37 AM |
| I'm Buying Soon...Suggestions '95 M3 or '96 M3??? | dapopa9 | 3 Series / 4 Series | 3 | 03-13-2004 01:10 PM |
| ZHP vs. M3 questions | hayasa | 3 Series / 4 Series | 23 | 07-04-2003 04:11 PM |
| M3 strut brace install questions | alee | Do-It-Yourself H.Q. | 26 | 06-14-2003 08:03 AM |
