E36 M3 (1995-1999)
Under panel flew off on hwy...
Is this a common problem?
![]() What do the OEM replacement parts run? |
Sorry Jon, welcome to the e36 club. At least you already have two of the biggies down (underpanel, and brakelight) now all you need is the thermostat and airbag light... |
![]() Yeah, I was going sort of fast (3 digits) when it came undone... Thanks for the info Josh. Okay, so I have heard about the radiator/H20 pump/thermostat, but not the airbag light... ![]() What's the deal with the airbag light? |
If it is the forwad underpanel, JT designs does a nice aluminum one.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
Do you know if the JT Designs panel is simple to install? Anyone here done this? I suppose that I'll need access to a lift? |
OH NOES!!!!!1 MY CAR HAS T3H UND3R5T33R5555!!!!!!1oneone!!!!11 Team WTF?! What are you gonna do?
I've helped install the JT one, and I don't know if I'd exactly call it 'nice.'
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline 1988 M6 Royalblau/Silbergrau Nappa |
I can't imagine needing a lift to do this. Jackstands are fine. Alex Last edited by BahnBaum; 05-15-2005 at 12:53 PM. |
A lift? Probably easier to hold the pieces up with the car close to the ground.
Thanks for the feedback...
Sounds like the aluminum panel may be unnecessary? |
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed 2002 BMW M3 Alpinweiß/Black 1999 323i KP/GTS2 Alpinweiß 1990 325is Brilliantrot/Tan 1989 325is S50B30US Alpinweiß/Black 1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
And THAT is the big point.
![]() I have mostly good things about them, but have no first hand knowledge. The LTW uses the splitter as the underpan.
cones or scraping over anything else, sounds like I probably won't need to go as extreme as the aluminum panel -- especially if the installation is not clean (read: pita)? Will the (OE) fasteners hold secure under normal (sic) driving conditions? The one that came off looked like it had been banged up previously on curb stops or something. |
JT designs plate is relatively simple, lots of fastening to do, if your wheel wells are messed up(missing or busted screw holes) you will need to replace them
Thanks for all of your input. I decided to go with OEM - the price was too good to pass
up from BMW Santa Barbara; "Internet/Bimmerfest Special" was about half of the price of the aftermarket. If I can get get another 6 years out of it that'll be great... |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| LeatherZ E46 Gauge Panel Install w/photos | Scott ZHP | E46 (1999 - 2006) | 40 | 07-06-2010 02:48 PM |
| 1996 318is drive panel lights don't work | Das Chimney | E36 (1991 - 1999) | 2 | 03-27-2008 04:04 PM |
| e60 Instrument Panel Blanked | quad | 5 Series | 0 | 12-31-2004 11:51 AM |
| 2003 and 2004 M3 Coupe left inside Trunk Panel | Zappo | M Series | 2 | 10-15-2003 04:44 PM |
