E34 (1989 - 1995)
Old 05-11-2005, 08:03 PM
densto densto is offline
Mein Auto: 1995 525i
Question e34 first gear problem
Hello,
I have a 95 525i with 170k miles original clutch and transmission. Lately I started having problems with my first gear. When I shift in to first gear and let clutch go, car starts to move and then kicks out of the first gear. I am not really technical person so please bear with me.
It does not happens all the time just once in a while and I always try to make sure that I completely shift in to the gear. What could cause this kind of problem clutch or transmission?
Thank you for the help.
Old 05-16-2005, 09:41 PM
jtw3 jtw3 is offline
Mein Auto: 1990 535i
This was also one of my problems with my 90 535i. (see clutch conversion query below). I replaced my shifter seat bushing and it helped alot. Make sure other parts of shifter linkage aren't worn. On my car, the problem is still there but I can feel the resistance going into first and also clutch drag when moving shifter out of any gear at a stop (flywheel problem).
You are correct to suspect the clutch and possibly the trans itself. Hope this helps.
john
Similar Threads
Gear Ratio Calculator? Gus E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 4 04-10-2012 07:08 AM
Last chance... accleration problem BrettInLJ 5 Series 5 05-17-2004 10:21 AM
different gear positioning akbmw81 3 Series / 4 Series 5 09-02-2003 06:25 AM
Anyone with the same problem? danpop 3 Series / 4 Series 3 12-31-2002 07:40 AM
