Old 06-15-2005, 10:18 AM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
Problems engaging 1st
Ever since I had a TSB job done on my clutch, it's gotten tougher and tougher to get the tranny in 1st. I don't see how they're related (unless the dealer screwed up the reinstallation), but it used to be that I'd only have to retry N->1 once a week or less. But since about a month ago, it's basically every time I come to a stop. I have to pump the clutch once or twice before 1st would engage. I have noticed that if the car is still rolling, it's much easier to engage.
I changed the tranny fluid over the weekend to see if that would help, and in fact it doesn't. My biggest problem is that my warranty is out in a week, and I'm afraid the damn stealer is going to blame it on my SSK...
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline
1988 M6 Royalblau/Silbergrau Nappa
Old 06-15-2005, 01:49 PM
ahwangbo ahwangbo is offline
Mein Auto: 1999 328i
I've got the same issue. In speaking with several mechanics, the consensus is that the clutch going. This is quite expensive...approximately $1K without the flywheel replacement.
By the way, what was the TSB? Do you have the number and description? Thanks.
Andrew
Old 06-15-2005, 02:28 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
The clutch is new from the TSB (it was for a bad throwout bearing for MY02 cars, actually) so it can't be that, can it?
Old 06-15-2005, 05:50 PM
TLudwig's Avatar
TLudwig TLudwig is offline
Stuck in Monday
Mein Auto: 2009 M3
Is the cable or shift linkage not properly adjusted?
2009 Interlagos Blue E92 M3 (Sold)
2004 Silver Gray 330Ci ZHP (Sold)
Old 06-15-2005, 06:49 PM
audiphile audiphile is offline
Mein Auto: Barney e36 m3
How many miles on the car?
there is something you can do - change the "lifetime" oil in your gearbox with Redline ATF and all will be good.. dont wait till you have metal flakes in your old oil, or it may be too late..
Oh yeah, chances that it is your clutch are slim, unless one of the springs on it is defective..
Similar Threads
2004 745i problems jdurst 7 Series & 8 Series 2 08-18-2004 02:49 PM
Need some advice on getting a good 6K rpms 1st to 2nd shift with a 330i. Moderato 3 Series & 4 Series 20 07-12-2004 05:00 PM
On-Going Problems @ Body Shop samlee4444 General BMW Questions 7 06-28-2004 05:25 PM
