Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Classic Bimmers
Classic Bimmers
Discussions pertaining to vintage and classic BMW models here...
Old 06-18-2005, 08:06 PM
2002Hawaii 2002Hawaii is offline
Mein Auto: 1976 2002
Troubleshooting
Hi. I recently finished a restoration of my '76 2002
When I finished the car, it ran great for about three or four days. Then it developed a fuel dilivery issue, so I flushed the tank, blew out all the lines, changed the filter, removed and cleaned the pick up, changed the fuel pump, and cleaned the carb. This seems to have solved the fuel dilivery issue, but now the car runs so lean it will harldy idle
I know it's lean because if I close the choke butterflies almost all the way, blocking off most of the air entering the carb, the idle smooths out, and the engine runs much better. I've tried another identicle carb, and had the exact same results.
The engine was totally rebuilt, with high compression pistons, but otherwise it is all stock. Both carbs are Weber 32/36, one was on the car when I bought it, and the other was on another 2002 that we used for parts. This is the first carburetted car I've worked on (I mostly work on imports) so I'm not to familiar with carbs in general. Any help would be apprectiated. Thank, Graham
Old 06-18-2005, 08:57 PM
Vroomer's Avatar
Vroomer Vroomer is offline
The only cars to drive...
Mein Auto: 2002, 3.0 CS, Z4 3.0i
2002 FAQ
Well, my '69 has a manual choke.. Also, what octane are ya using? You being nice or mean to her? Since you have "high compression pistons" now.
Ask there.
~Vroomer
I know the bolt of cloth I was cut from.
Old 06-18-2005, 09:31 PM
It has an automatic choke, which seems to work properly. I'm using 92 octane gas
Old 06-19-2005, 11:18 PM
RedSilver's Avatar
RedSilver RedSilver is offline
Between Law and Oblivion
Mein Auto: Z3
Massive vacuum leak from a hose loose.....
...easy to check with a vacuum gauge, if you can keep it idling long
enough.
RedSilver,
CEO of the Upper East Side Locos, the Kinder, Gentler Gang
Old 06-22-2005, 11:17 PM
Thanks guys. The brand new fuel pump was defective, and there was some crud in the carbs. I replaced the fuel pumps and rebuilt the carb, and the car runs great. Thanks.
Similar Threads
Help Troubleshooting Shifter Vibration ? Patrokloss E36 (1991 - 1999) 20 12-22-2011 08:22 AM
BMW Noise Troubleshooting Alex Baumann General BMW Questions 3 08-14-2008 02:40 PM
Help with troubleshooting electrical failure... DannO E36/7 Z3 (1996-2002) 17 07-26-2005 08:50 PM
Need help troubleshooting - Drop in Performance BrettInLJ 5 Series 4 10-22-2003 10:49 AM
Wireless Network Troubleshooting question – silroc Off-Topic 8 09-02-2003 09:17 PM
