E46 M3 (2001-2006)
Old 06-19-2005, 02:52 PM
eluder eluder is offline
Mein Auto: 03/ZHP, 03/Z4, 01/325
A few issues with my M3 Coupe. Anyone else with something similiar, or tips?
I started hearing an noise on my 05 M3 coupe this morning and I'm going to take it in this week I hope. Basically, it seem that around 3900-4100 RPMs, there's a rattle. It's like a metalic "buzzing" sound. It happened in the 2 gears I tried, 1st and 2nd. It's generally reproducable.
The next issue is what sounds like the window cracking when I roll the driver side front window up. Little brief "pops". Once or twice when going from full down to full up. It doesn't happen every time, but about 90% of it.
The last is a "pinging" in the rear end when manuevering over something that flexes the chassis. This very well may be normal, but my 330 didn't do it, so I thought I'd ask. The noise is definately coming from the rear end and sounds like someone flicking the tire with their finger. It doesn't really sound metallic, though I could be wrong. It seems to only happen in the morning or after the car hasn't moved in a bit. Speed seems to play no role in occurence.
I'm most concerned about the first one, but would appreciate any comments regarding anything. Thanks a lot.
Old 06-19-2005, 02:59 PM
RChoudry's Avatar
RChoudry RChoudry is offline
Send a message via AIM to RChoudry
Mein Auto: 86 325es; 87 325iC; 06 M3
maybe the catalytic converter cover. easy fix. the others I can't say.
The five Dís of dodgeball: dodge, duck, dip, dive, and dodge.
-2006 Z4 M Roadster (Sapphire Black/imola red)...12/9/2006
-2006 M3 ZCP Interlagos blue/black via PCD 11/29/2005
-2004 330i ZHP Imola red/black alcantara CPO 1/2008
-1999 Audi A4 1.8tQ (Jaspis Green/Black)
-1986 325es (Zinnoberot red/Pearl)
Old 06-19-2005, 03:00 PM
Thanks for the quick reply. Is this common enough he'll know what it is? I'm afraid I'll get there and be unable to reproduce it and end up looking like an ass.
Old 06-19-2005, 06:48 PM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
... isn't that sound the "rasp"?
Old 06-19-2005, 07:22 PM
I don't think so. I definately know the "rasp" at least I think I do. This sounds like a rattle as it's a new noise.
Old 06-20-2005, 11:53 AM
bdb bdb is offline
bewilderbeast
Send a message via Yahoo to bdb
Mein Auto: 13 Audi A5
I have what appears to be a clunk or something which seems like it comes from the rear parcel tray at what you said, any speed and when the terrain changes, I never really notice it as I have music on, but my parents are visiting, and my mom loves to point out things like that.
Old 06-20-2005, 12:26 PM
sky sky is offline
Mein Auto: 2015 335i
That happened to me also...It could be a window regulator bolt that is working
its way loose. Check out this post: http://www.bimmerfest.com/forums/showthread.php?t=67161
Old 07-08-2005, 10:34 AM
Riuster's Avatar
Riuster Riuster is offline
Riuster = Rooster
Mein Auto: 02 M3, 07 X3 and 04 TSX
sounds like your syncrhos from your tranny.
well then your window motor has issues.
do you have OEM stock wheels, what about brake pads, how about the shock mounts?
Tranny.
02 CB/Blk Lthr, Cold/Prem. Pkgs, HK, Xenon, Rev. Alert, SMGII, ACS comps, Hamann Comps, OEM Bar, Intros Aero Pol 19s 2-3 In.lips, w/275 Potenzas, Koni S, RMS, AA GEN3, SS Midpipes, DDE lights, LED Retrofit, Lthr Steering, OEM Sheepskins, Kewood Amateur 7000, XM 2, V1, GT2, Garmin 7200, Carputer-SONY T140 with Xenarc display, CSL splitters, ACS diffuser
BMW 2007 AW X3, prem and cold pkg.
Acura 2004 CG TSX
Old 07-09-2005, 08:55 PM
Car is 100% stock.
Old 07-11-2005, 06:09 PM
e36M3r's Avatar
e36M3r e36M3r is offline
Mein Auto: e46 M3
I have it too... on occasion, only when cold.
M3 05 Imola/Black, ZCP, ZPP, SMG, Xenon, Nav, Heated, Lumbar, HK -- Euro Delivery Pictures
Old 07-12-2005, 11:40 AM
Interesting. It seems to have disappeared now. I'll keep an ear on it.
Old 07-12-2005, 08:52 PM
e36M3r's Avatar
Mein Auto: e46 M3
That noise I'm not worried about... just figured it was a sign it's not warmed up yet. Seemed like something from the exhaust.
I'm not at all pleased with a minor rubbing sound from the differential when going very slow and making sharp left turns and somewhat on right hand turns also.
I'll say one thing, the e46 certainly makes much more noise in almost every way then the e36.
Old 07-17-2005, 07:18 AM
atomicdoc atomicdoc is offline
OKTOBERFEST 4EVER
Mein Auto: 2005 M3/2001 325i
the famous clunk is what i took my '05 in twice to my SA for. i had to drive the chief mechanic around to reproduce the sound and they replaced both my rear shock mounts. someone on the m3forum also had this problem and he said the spring weren't "seated(?)"
properly.
anyways good luck with yours
George
Similar Threads
Bimmerfest Caravan Route, in case anyone missed it MarcusSanDiego General BMW Questions 19 05-02-2007 09:55 PM
For Sale: 2002 M3 Coupe CPO !!! rdhdnaflyryd Cars - Private Party 2 06-08-2005 03:39 PM
ZHP Coupe or M3 Coupe Msnowdon E46 (1999 - 2006) 41 05-05-2005 05:06 PM
Wow! The G35 Coupe looks good! (link inside) Sean Off-Topic 12 03-29-2002 11:48 AM
M3 or M Coupe toshweir27 General BMW Questions 12 02-22-2002 05:52 PM
