Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E46 M3 (2001-2006)
E46 M3 (2001-2006)
Old 07-17-2005, 04:25 PM
GoSlow2GoFast GoSlow2GoFast is offline
Mein Auto: 2004 M3
Rear Conti's shot ar 25,000 miles?
2004 M3, 19" OEM wheels with OEM Conti's. The fronts look decent, but the inside edges of the two rears are just about used up, just starting to see signs of the cord showing. Center of the tire still has life left in it though. Car has never been hit or damaged, is this type of wear normal on a new M3? I'm not one to be spinning the rears off the line, I prefer to enjoy the cornering of the car. Just trying to get a feel for if the the rear camber could be off, or if this is expected.
Old 07-17-2005, 04:39 PM
e36M3r's Avatar
e36M3r e36M3r is offline
Mein Auto: e46 M3
You must be real easy on them... I would get 15-18K on my e36, haven't got that far on the e46. Yes, definitely the rears wear out first.
M3 05 Imola/Black, ZCP, ZPP, SMG, Xenon, Nav, Heated, Lumbar, HK -- Euro Delivery Pictures
Old 07-17-2005, 06:17 PM
bren's Avatar
bren bren is offline
///Mpty pockets
Mein Auto: wankermatic
You're driving around with cord showing on your tires?
Old 07-17-2005, 06:36 PM
Stuka Stuka is offline
Mein Auto: German
When I had mine, the rear lasted about 10K on a good set, 8K sometimes.
But, that included some track time and some sideways action.
Bottom line, 25K is more than reasonable.
06 M3 6 speed CB/black ZCP
13 STI sedan WRB/alcantara
14 Evo GSR White/black
Old 07-17-2005, 06:52 PM
Mein Auto: 2004 M3
It's just a small line a couple of inches long, and thin like the line from a pencil. I just noticed it today, and they will be getting replaced this week. I just wanted to see if the inner wear patter was typical.
Old 07-18-2005, 05:04 AM
jayf jayf is offline
Mein Auto: 2002 m3c
I get about 18000 on my rears and twice that on my fronts. There is no uneven wear. I did not have uneven wear though. You probably have an alignment problem which should be checked.
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 12:44 AM
Rear Fog Light Research (post-facelift E46) bluer1 3 Series & 4 Series 99 08-09-2004 12:46 AM
Service info needed for 60k mile interval Maximus 3 Series & 4 Series 5 04-04-2004 05:53 PM
Is it ok to just replace my rear tires with S03s? I have Contis on the front. ESS 3 Series & 4 Series 16 05-29-2002 07:56 AM
17k miles and my Conti's in the rear are almost gone! ayn 3 Series & 4 Series 17 04-17-2002 05:11 PM
