Old 07-23-2005, 02:04 PM
thepurpleblob thepurpleblob is offline
Mein Auto: 525d
Can somebody explain the Parking Distance Sensor
I was looking at a 525d today with the PDS. I expected that it would only work when the vehicle is in reverse. However when after reversing against a wall, I put it into Park and it continued to sound. Is this correct, and if so why?? I can see that being very annoying.
Also, the ones at the front didn't seem to do anything when I approached a wall to park front first. Do I have to do something to activate them or might they be faulty.
Any advice appreciated.
Old 07-23-2005, 04:06 PM
Brevity= the soul of wit
If the PDS was factory installed prior to '01 (I think) it was only on the back bumper. If that's the right year, then after '01, it was on both front and rear. If it was the part available from a BMW dealer offered as a retrofit, it was offered only for the rear. Of course, this is all US info. Who knows what was avail elsewhere.
It should not continue to sound after placing the car in park.
Old 07-23-2005, 04:51 PM
ketchup's Avatar
ketchup ketchup is offline
Wrenchin'
Mein Auto: E46 M3
hmmm...on my 01 it will continue to beep after placing the car in park, I also have the sensors on the front. take a look at your front bumper, it should look similar to the rear with those four round sensor spots. the sensors will automatically shut off after driving past 5mph I believe, you can always turn it off if it bugs you.
Old 07-23-2005, 07:17 PM
King's Avatar
King King is offline
Mein Auto: X5 4.4i
Okay here's how the PDC works...
It is normally off and will not sound if you are approaching something ahead. However when you put the gear in reverse, it automatically switches ON and will sound when you are approaching something behind you. It will stay ON when you put the car in drive for a short while. This assists in sensing an object both in front and behind you, like when parallel parking for instance!
Old 07-23-2005, 07:19 PM
SRFast's Avatar
SRFast SRFast is offline
Mein Auto: 2003 BMW 530i
The BMW's Parking Distance Control (PDC) system is activated automatically whenever REVERSE gear is selected. Both the front and rear sensors are active when the system is engaged. The system automatically deactivates when the vehicle moves forward approx. 160 ft or exceeds 20 MPH. The PDC system can also be activated/deactivated manually via a dash mounted PDC switch. Most models have front and rear sensors, but the 3 series has only rear sensors. BTW, the tone of the front and rear distance "beep" is different. Addressing your last question, since the PDC is not always active, it will not beep unless the car has been put in reverse or the dash switch is depressed.
Hope this helps...JL
2003 530i 5spd/SP/PP/CWP/PDC/RSAB/Xenons
Old 07-23-2005, 08:50 PM
Thats weird, the PDC on my X5 doesnt sound after the car is put in... ohh wait.. it DOES! But I guess I am usually so close to taking the key out that I'd forgotten! Ah HAH!
Ok, so on to the front vs rear. Does ANYone remember that BMW offered a retrofit kit for E39's that was avail only for the rear? I just caught that he has a 525, so that *could* mean it's at least an '01 unless that model was avail earlier in Europe.
My last comment on PDC is that it makes for worse drivers. Now, when I'm in the E46 or E39 (both w/o), I almost always get WAYYY tooo close waiting for the beep like in the X. Oddly, that doesnt happen when I'm in the '02.
Old 07-23-2005, 10:45 PM
ketchup's Avatar
Wrenchin'
Mein Auto: E46 M3
20 MPH? I forget how fast these cars reach 20mph..i just figured it would go off the same time your doors would lock, if you have that programming.
haha your too spoiled by the pdc, just like me! whenever i'm reversing in another car i'm always waiting for that flatline, til I realize that it isn't equipt with pdc.
Old 07-24-2005, 06:56 AM
Thats when my turns off. The light on the dash goes off at exactly the same time.
Old 07-24-2005, 12:43 PM
ketchup's Avatar
Wrenchin'
Mein Auto: E46 M3
back to the auto doors, sometimes after I stop and unlock the doors, they don't re-lock after I drive off again (i.e. after I drop someone off.) It will work once in a while but most of the time they will not re-lock.
Similar Threads
Parking Brake Adjustment DIY ChrisF Do-It-Yourself H.Q. 23 05-21-2013 09:56 AM
Parking at Bimmerfest scottn2retro Bimmerfest 2005: Santa Barbara, CA 23 04-22-2005 06:24 AM
Cam Sensor & EVAP questions akz3 E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 1 02-25-2005 07:04 PM
Need help determining sensor part TeamM3 E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 9 09-09-2004 07:43 PM
