E36 (1991 - 1999)
Old 08-04-2005, 07:28 AM
hopesbeemin325i hopesbeemin325i is offline
Mein Auto: 01' 325i
Question shock moont ?
does the big washer on the shock mount go on top of the mount or the bottom. cause i think someone told me wrong or i am not very good with cars. so if you know thanks
Old 08-04-2005, 08:18 AM
operknockity's Avatar
operknockity operknockity is offline
My TARDIS is a BMW
Mein Auto: '02 325i
Are you talking about #6 or #10 (both being "big washers") in this parts breakout:
BTW... The diagram and a parts description are at http://www.realoem.com/bmw/showparts...86&hg=33&fg=45
How many posts could a repost post if a repost could post posts?
Old 08-04-2005, 08:25 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
You need big washers on the top AND bottom.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 08-04-2005, 08:47 AM
Mein Auto: 01' 325i
The Dealer Said I Needed One And They Didn't Tell Me Were It Goes. It Is For A 93 325i 4dr
Old 08-04-2005, 08:52 AM
*shrug* A shock is pulled and pushed. There are two different bigass washers. One goes on top, one goes on the bottom, and if you don't get both, you're goign to keep popping shock mounts.
Old 08-04-2005, 09:04 AM
Mein Auto: 01' 325i
ya i have one on the bottom and thats it. well i will have to find the top ones i guess. do were else to get these
Old 08-04-2005, 09:06 AM
dealer. Get it ASAP.
Old 08-04-2005, 11:06 AM
Riuster's Avatar
Riuster Riuster is offline
Riuster = Rooster
Send a message via Skype™ to Riuster
Mein Auto: 02 M3, 07 X3 and 04 TSX
replace those shock mounts with rogue engineering RSMs...
www.rougeengineering.com, look under RSM, best Ive seen so far...and you never have to remove your trunk liner again to replace or adjust adjustable rear shocks.
02 CB/Blk Lthr, Cold/Prem. Pkgs, HK, Xenon, Rev. Alert, SMGII, ACS comps, Hamann Comps, OEM Bar, Intros Aero Pol 19s 2-3 In.lips, w/275 Potenzas, Koni S, RMS, AA GEN3, SS Midpipes, DDE lights, LED Retrofit, Lthr Steering, OEM Sheepskins, Kewood Amateur 7000, XM 2, V1, GT2, Garmin 7200, Carputer-SONY T140 with Xenarc display, CSL splitters, ACS diffuser
BMW 2007 AW X3, prem and cold pkg.
Acura 2004 CG TSX
Similar Threads
For stripped out rear shock bolt holes (e36) scottn2retro Do-It-Yourself H.Q. 0 04-30-2004 03:09 PM
Koni Rear Shock Adjust: Can I Do This? CMOS Do-It-Yourself H.Q. 9 10-07-2003 09:52 PM
