E36 (1991 - 1999)
Foglight Bulb Replacement Procedure
Hello all. I'm a long time lurker whose wife has a '97 328i Convertible. It's not her car that prompted the post, however. My daughter's boyfriend has a '97 328i Sedan and he called in desperation when he got the dealer's estimate for just replacing the foglight bulbs. He wants to do it himself to save some $$ but he lives 250 miles away, so I can't help him do it. Does anyone know a simplified procedure for the task that I can e-mail him, or a link to a site that has good step-by-step instructions?
Thanks in advance for any help you can give. Vince
Just did this *today* myself, dead easy DIY job, you can have it done in 15 minutes no joke, all you'll need is a flathead screwdriver of reasonable length.
To the "inside" side of the foglight (towards the car centerline) there will be a lttle square gap in the grille/bumper, where you can see a hex-bolt (or a phillips screw head) for adjusting the foglight aiming. Pop your screwdriver in there, blade vertical, and just move it around gently an inch or two in until it hits something solid but with a little give, and push gently. If you're in the right spot, you'll be pushing on the clasp that holds that side of the entire foglight in, and it will pop out. Slide it out and towards the centerline of the car and it the whole thing will just come out. Unplug the foglight wiring, just a simple clip there. Twist the shroud on the back about 1cm and it'll come off, the bulb is inside held down by small metal tension wires. Just unplug the hot wire from the old bulb, release the tension wires, and it'll come right out. Replace, the bulb and wires, slide the foglight's "outside" pins into the grooves, then push on it, holding onto the bottom of the air dam with your other hand, until it "clicks" back in. All done. If you need, I can take some pictures. ----DO NOT JUST "PRY" THE FOGLIGHT OUT AS SOMEONE HERE ONCE RECOMMENDED---- This will break the very small and fragile plastic clip that holds the "inside" side of the foglight in, and the foglight will not stay in if that clip is broken. I got the whole kit from BAV and lucky thing, since I broke one of them in this fashion myself today and had to replace the whole foglight assembly which is obviously meant to be done with the air dam / bumper off the car -- hard to get those screws out with it on. Anyway, if that's not enough, I could take a few pictures for ya. Good luck! |
Thanks for the quick reply. I will pass on your most excellent instructions.
Vince |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2001 325i Headlight Bulb Replacement | skyhook | E46 (1999 - 2006) | 7 | 11-10-2011 10:01 AM |
| Consumer Alert-bmwxenon.com | bmw528im5 | General BMW | 6 | 02-21-2005 11:00 AM |
| replacing e60 foglight bulb | surewin | 5 Series | 3 | 11-29-2004 01:46 AM |
| F/S: New 6500k 9006 HID replacement bulb | James92se | Classifieds | 0 | 11-18-2004 11:49 PM |
| Foglight Bulb Replacement | absolut ci | Do-It-Yourself H.Q. | 2 | 11-26-2002 08:33 PM |
