E34 (1989 - 1995)
Old 09-06-2005, 02:42 AM
mbilic mbilic is offline
Mein Auto: BMW e34 535i
transmission problem
hi all,
i have an 88'mod e34 535i, and am having problems with the auto.
when the motor (or eng. temp is cold) tranny wont shift into second gear. i try shifting manually through the gears but still stays locked into 1st.
once the engine temp gets to half way on my gauge(which is normal running temp) the gearbox shifts fine, like there was nothing wrong at all with it.
i had the computer scanner and the only errors were 0xygen/exhaust sesor(which i know wont have any affect on the tranny), and something along the lines of "not enough voltage going to gearbox?!?!"
i took out the plug that goes into the gearbox and spayed it with electrical contact cleaner and cleaned it out but nothing improved.. can some1 plz help me? most appricated,
Mark
Old 09-13-2005, 07:24 AM
m5maniac m5maniac is offline
Mein Auto: 92 525iT
this might just be somthing that the transmission does. It has somthing programmed into it so that the shifts are longer when the tranny is cold. Mine does the same thing but it dosnt like shifting to 3rd.
How long since you have changed the tranny fluid? I noticed a big improvement when i did that.
Hope this helps
Old 09-16-2005, 11:04 PM
imnprsd imnprsd is offline
Mein Auto: 1992 525i Wagon
If you have a gear selector switch...did you clean that? ... Also, my tranny performed better after I changed the fluid and filter. Just don't over fill the tranny if your car does not have a dipstick.
Similar Threads
Transmission Problem Gear 5 Ratio Incorrect Code 0735 ? durbanite1 E46 (1999 - 2006) 18 06-08-2010 08:34 PM
740i Transmission module control problem nensslen 7 Series / 8 Series 11 02-24-2005 07:12 AM
Diagnosing transmission problem with a Nissan Maxima guitarman General Automotive Forum 8 01-17-2005 11:31 PM
Service Center and Warranty Problem (Transmission) wildag 3 Series / 4 Series 11 01-11-2005 08:29 PM
323/325 328/330 etc. engine changes Optimus Prime General BMW 15 04-03-2004 06:56 PM
