E34 (1989 - 1995)
Old 09-24-2005, 03:56 AM
imnprsd imnprsd is offline
Mein Auto: 1992 525i Wagon
Interior Lights Don't Work (1992, E34)
I have a 1992 BMW 525 wagon and the interior lights do not work. I discovered that no power is getting to the map light and the other interior lights. I'm thinking that's because the Control Module is not switching the power on.... And that leads me to think that maybe the door switch is not working. Do you think this could be the problem?
All my other accessories and electrical system is checking out fine. Help!
Old 09-26-2005, 12:23 AM
Still looking for an answer. I checked the door microswitch and it's okay.
To me the door microswitch is normally open and when you lift the lever it closes the circuit (short) which tells the CM the door lever has been lifted. You can test this without removing the lock by removing the door pannel and separating the right-most (gray) connector and doing a continuity test; i.e., when lifting the door handle the meter should indicate a short.
In my case the door switch is okay.... So why aren't my interior lights getting power? I'm now thinking it's the relay in the CM. However, I'm always open to new ideas.
Question: There are three electrical connections to the door handle and all three are nicely accessable and color coded. There is a white, yellow, and gray connector.... but what do they do?
...I know the gray connector is the door micro switch since it shorts out when you open the door handle.
... And the yellow switch has 12V going on one side and gnd on the other, but I'm not sure what it does?
.... And the which switch is completely unknown to me.
Anyone know what the yellow and white connectors are for?
Old 03-23-2013, 10:21 PM
DanM5's Avatar
DanM5 DanM5 is offline
My other ride is ur wife
Mein Auto: 535is-m
Hey just wondering how you got on with this......8 years ago?? My interior lights come on when the boot/trunk is open but not if the doors are open, or even if I switch it manually... Any ideas??
Get in, sit down, hang on, shut up!!
Old 03-24-2013, 07:48 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Hey Dan. With him having only 53 posts and this thread being from 8 years ago, I doubt he will respond.
You may want to try sending him a PM since it will go to his e-mail as well (assuming he still has the same e-mail address).
Most problems are usually something simple !
Originally Posted by noego View Post
It's Deja Poo - as in, I've heard this **** before.
Steve
Calypso Red 1992 525i with 225K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-24-2013, 01:37 PM
DanM5's Avatar
Mein Auto: 535is-m
I just did a thread search of my problem an he came up.. Thought I'd chance my arm..!
Old 03-24-2013, 04:32 PM
DanM5's Avatar
Mein Auto: 535is-m
Any1 else know what the issue mite be??
Old 03-27-2013, 07:57 AM
manuelwindows manuelwindows is offline
Mein Auto: 1994 530i, 1977 320i
could be the fuse in the front engine compartment fusebox that corresponds to the interior lighting. I pulled mine because I think it was also providing power to the glove box flashlight charger and I suspected it was slowly draining my battery over long periods so I just pulled it and haven't had any battery issues since then.
So I don't have interior lights except if I stick the fuse back in there. I forget offhand which fuse it was, you can check Bentley's for your model, but it could be that.
Old 03-27-2013, 01:12 PM
BMWFatherFigure's Avatar
Old School
Come on round Dan - We will DVM the car until we find it. Can't be that hard.
Current:
E38 Parts Car
Previous:
Old 03-27-2013, 01:34 PM
BMR_LVR's Avatar
Humble E34 lover
What a nice gesture
Hope you get it fixed. Let us know what resolved it if you do get it fixed.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-27-2013, 01:51 PM
DanM5's Avatar
Mein Auto: 535is-m
Manuel I have lights when the boot is open, just not the doors.. My battery isn't draining and the fuse is checked and fine.. It'll be something else, with BMWFF's help we'll figure it out..
Similar Threads
Work Problems....Advice? Optimus Prime Off-Topic 29 09-24-2004 08:03 PM
E34 M5 purchasing m5forme 1M & M2 2 06-02-2004 04:50 PM
E34 or E36 Michael330 General BMW Questions 44 08-25-2002 05:59 AM
