The X5 SAV Forum
Old 09-26-2005, 03:01 PM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
X5 battery replacement
I replaced the battery in my wife's X5 3.0 yesterday. It hasn't left her sit yet, but it will be 5years old in Feb. Since I'm the one who will get the lucky phone call to retreive her when it does die, I figured I'd do it proactively on my own terms.
Anyway, the OEM battery is a Douglas 94R. It is identical to the factory installed battery, the only thing missing is the BMW sticker. I called around and found one at a BatteriesPlus store about an hour away from me for $89 (no deposit). Dealer wanted $299.
Douglas sold their battery division this summer to East Penn Manufacturing, near Reading PA. FWIW, the X5 battery will be manufactured under the Deka brand name and sport a black case.
Took about 30mins to R+R and that included cleaning out the beach sand from the hatch/trunk well.
ID:	57978   Click image for larger version
ID:	57979   Click image for larger version
Old 09-26-2005, 08:55 PM
dkl's Avatar
dkl dkl is offline
Mein Auto: E53 X5, E86 Z4MC
Thanks for sharing. Just curious...did you plug a charger or something in the cigarette ligher to keep things from getting reset?
Old 09-27-2005, 08:01 AM
Scott ZHP's Avatar
We want the Lion!
Good question; I though about it, but didn't. I searched the TIS for battery replacement and didn't come up with anything specific to the E53/X5. Just generic stuff on the safe handling of batteries, how to properly jump start, etc.
After I installed the new battery and started the car, the airbag light and the DSC warning "triangle" lit up. I left it charge for a few mins figuring they might self reset. They didn't. I shut it off, restarted it a few minutes later and drove out of the garage; within 20 feet the dash chimed and they reset themselves.
Interestingly, I didn't lose my radio or my seat presets. Everything stayed in memory.
Old 02-11-2008, 10:36 AM
fetener fetener is offline
Mein Auto: bmw x5 2002
X5 Battery Replacement
How do you get to the battery in order to replace it? My husband is going to do it but as with everthing with the bmw's there is always a trick to it.
Thanks!
Old 02-11-2008, 01:33 PM
motordavid's Avatar
motordavid motordavid is offline
RetiredBum
Mein Auto: '01 X5 3.0 '02VetteVert
Thanks!
Lift out rear deck panel, pull out spare tire and have at it!
The black turtle looking cover has only three bolts that hold it down:
undo those and lift it out of the way.
Here's my DIY post with pics from another board...also see link at end of first post,
just above first pic, for detail on which bolts to undo from "turtle", if that is confusing.
Be certain to reinstall the vent tube on battery. Whole job is <30mins, including breaks.
Easy stuff.
GL,mD
http://www.x5world.com/x5-e53-forum/...apped-out.html
Ol'Uncle Motor
'01 X5 3.0 Sport, 5 Spd Manual, etc.
'02 VetteVert 6 Spd, Z51 susp.
'10 Hyundai Tucson for the CEO, & 3 Assorted M'Cycles.
BMW CCA mem. Tarheel Chapter
My Flickr...Scenes,Cars & Road Trip Pics:
http://www.flickr.com/photos/45275375@N00/
Old 09-11-2012, 09:03 AM
maba maba is offline
Mein Auto: X5 e53 Diesel
Smile Need advise!!
Hi, I own a 2004 X5 E53 diesel, I am from Melbourne Australia and I am not quite sure if CCA ratings differ in different parts of the world due to weather conditions however my battery is rated 720 CCA and I am curious if you had fitted a battery with an identical CCA rating. Is it ok to replace with a higher CCA rating? I spoke to a BMW dealership and he advised if you are replacing with a non genuine battery it must have exact CCA rating to avoid issues.
Thanks in advance,
maba
Old 09-11-2012, 09:12 AM
Scott ZHP's Avatar
We want the Lion!
Thanks in advance,
maba
Higher is fine. Lower might be an issue, especially for a diesel (they're harder to start).
I have replaced this battery since authoring this thread. The best battery on the market for the E53 is the Deka "Exact Fit" EAS9AGM49. It's AGM/valve regulated and something like 1100CCA.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 09-19-2012, 04:54 AM
Hi all,
For members in Melbourne Australia, Just wanted to share with everyone my experience regarding a battery replacement for my X5. To put it simply BMW wanted $455 for the battery plus $110 to initialize it. Naturally did some research and found a Bosch battery designed for european cars which is perfectly suited to the cars specs regarding dimentions and CCA 800 for just $275 (part number 60038) including a 15% discount fitting inclusive. The company is HOLLYHOCKBatteriesPLUS located at 35 Yarra Street Abbotsford Victoria 3067. Check out their website. Anyone interested is eligible to receive 15% discount when you mention this forum. Excellent service!! Very happy...All the best.
Regards
MABA
Old 09-20-2012, 09:51 AM
bowang bowang is offline
Banned
Mein Auto: 2007 X3
I installed a new battery (AutoCraft H8-AGM) from Advance Auto Parts last Saturday. So far everything works great. It's only $125.99 after using a link my friend sent to me. The link saved me $35 instantly. The battery can be used on X3, X5 and 5 Series. I got free installation at local store.
Here is the link (up to 40% on everything): http://advanceautoparts.**************************
H8-AGM Spes:
Acid Included: Yes
Battery Type: AGM
Battery Usage: Auto/Truck
BCI Group Size: H8
Cold Cranking Amps: 900
Cranking Amps: 1000
Deep Cycle/Starting: Dual Purpose
Maintenance Free: Yes
Reserve Capacity: 160
Terminal Type: SAE
Weight: 59.45
Length: 13.94
Width: 6.938
Height: 7.5
Warranty:
7 Year Warranty (3 Year FREE Replacement)
Old 12-10-2012, 01:06 PM
GPSnV1's Avatar
GPSnV1 GPSnV1 is offline
Mein Auto: X5 5.0i
H8-AGM Spes:
Acid Included: Yes
Battery Type: AGM
BCI Group Size: H8
Cranking Amps: 1000
Terminal Type: SAE
Weight: 59.45
Length: 13.94
Width: 6.938
Height: 7.5
Warranty:
Has this worked out well for you?
2008 X5 4.8i. 2012 X5 5.0i retired, 2004 X4 4.4i retired
BS RL/EL, Max 360, V1 (3.894) V1C LE/V1 Driver
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS
Old 12-10-2012, 01:28 PM
Banned
Mein Auto: 2007 X3
Yes, the battery has worked great so far.
Similar Threads
Odyssey battery in M-coupe Bob Clevenger E36/7 Z3 (1996-2002) 15 05-20-2007 12:26 AM
My first BMW service (please advise what you would do)? shaftdrive E39 (1997 - 2003) 23 08-18-2006 08:51 PM
e61 touring vs x5 3.0 wagonman E60 / E61 (2004 - 2010) 37 05-20-2005 05:48 PM
replacement carpet X5 sdkinion X5 E53 (1999 - 2006) 4 03-29-2005 05:09 AM
'04 X5 Battery vdt04452 X5 E53 (1999 - 2006) 2 08-26-2004 04:29 PM
