E60 (2004 - 2010)
Old 09-30-2005, 09:57 AM
Spartacus_33's Avatar
Spartacus_33 Spartacus_33 is offline
Spartacus_33
Mein Auto: 2008 Black Jeep Wrangler
Hubcentric Wheel Spacers?
Anyone have any experience buying wheels that require hubcentric spacers?
Apparently Ronal wheels require the use of them. Just wondering if there are any known problems with vibration or having them come loose.
Any comments would be appreciated.
Thanks,
Spartacus_33
2012 Audi Q5 3.2
2005 Jet Black/Black 545i - Retired
1999 Jet Black/Black 528i - Retired
1996 Jet Black/Black 328i - Retired
Old 09-30-2005, 11:07 AM
DZeckhausen's Avatar
DZeckhausen DZeckhausen is offline
Send a message via AIM to DZeckhausen
Mein Auto: 2012 BMW F30 328i 8-Speed
I think you meant to use the term "centering rings" rather than hubcentric spacers.
If a wheel manufacturer wants to save money, they can bore out the hub to a diameter larger than all of their various applications. When they sell that particular wheel to, say, an E39 540i owner, they include a centering ring that necks the hub centerbore diameter down to 74.1mm. They can sell the same wheel to an E60 5-Series owner by including a centering ring that is thicker and necks the centerbore down to 72.5mm.
Using this technique doesn't imply the wheel manufacturer is inferior. For example, many BBS wheels use PFS (I think that stands for "Precision Fit System") centering rings. As long as the centering ring is good quality and accurately machined, you should have no problems. If the centering ring is made of plastic, insead of metal, you may have problems if you take the car to the track, since the excessive heat may damage the plastic rings. But that's only my theory. It may be a non-issue thanks to modern, high-temperature plastics.
Dave Zeckhausen
Owner, Zeckhausen Racing
2012 BMW F30 328i Luxury Line 8-Speed
StopTech 4-wheel big brake upgrade
2001 BMW E39 540i 6-Speed (Traded-in for F30)
M5 Limited Slip Differential, Front Swaybar
Dinan Stage 3 Suspension, Strut Tower Brace
Rogue Short Shifter, Transmission Mounts
European Dash Conversion
CDV deleted
Old 09-30-2005, 11:20 AM
Spartacus_33
These are exact fragments from a couple of e-mails from Ronal to me.... "Hubcentric spacers are $25 each."
"The hubcentric spacers attach inside the wheel and are hubcentric to the
car. TUV approved
Thanks,
Spartacus_33
2012 Audi Q5 3.2
Old 09-30-2005, 11:54 AM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator 5-Series
Mein Auto: Trek 6500 MTB
Well, don't get lost in the wording:
Hubcentric: centered around the hub
Centering ring: ring centered...around the hub I presume
Same thing I believe.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles)
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have)
Similar Threads
New E39 5 Series - H&R 15 MM Wheel Spacers / Bolts / McGaurd Wheel Locks ashok Wheels and Tires 0 09-18-2005 04:33 PM
Need Help Finding Wheel Spacers For E90 bhattimalik E90/E91/E92/E93 (2006 - 2013) 1 09-08-2005 02:07 AM
rs110 wheel on m-coupe/roadster rukman E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 2 06-10-2004 10:11 PM
Wheel spacers JPinTO General BMW 4 09-21-2002 06:30 AM
FS: Carbon Fiber Wheel Cap Decal Kit vinnymac Classifieds 0 05-29-2002 09:36 AM
