Headrest - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 10-02-2005, 11:10 AM
tcar tcar is offline
Mein Auto: 1995 525it
Headrest
My headrest on my drivers seat does not retract. The motor runs when the switch is pushed, but nothing happens. I would be satisfied to just get it down. Any suggestions?
Old 10-02-2005, 07:10 PM
Cambridge Cambridge is offline
Cambridge
Send a message via AIM to Cambridge Send a message via MSN to Cambridge
Mein Auto: 1995 BMW 540i
Simple Fix
Here is a fix. It is similar to the twisted seat back fix. Click Here
Old 10-13-2005, 03:57 AM
imnprsd imnprsd is offline
Mein Auto: 1992 525i Wagon
If your problem is mechanical.... Like your seats there is a cable that comes out of the motor. To fix it:
-- Remove the seat back -- just lift up!
-- Remove the 2 screws which hold the cable casing tight against the motor
-- Remove the cable
-- Remove the metal cover piece by ripping it off the end of the casing
-- Cut the casing by about 3/8 to 1/2" and replace the metal cover piece
-- Put the cable back inside
-- Replace the two screws.
-- Test for full travel. (I don't think there are stops but I could be wrong.)
Old 10-13-2005, 03:59 AM
-- Remove the cable
-- Remove the cable
Old 10-13-2005, 01:50 PM
SharkmanBMW SharkmanBMW is offline
On the HI-Way of Life
Mein Auto: '94 540i, '03 330Xi
you can also go to http://www.bimmer.info/forum/forumdisplay.php?f=10
and search the archives for "headrest"
or "seat twist"
Similar Threads
Seatbelt wrapped around the headrest (need help) shaftdrive General BMW Questions 31 02-25-2013 01:30 PM
Questions on installing headrest monitors... King X5 E53 (1999 - 2006) 17 12-20-2004 01:36 PM
Have you noticed the headrest position on many cars has been moved forward AF General Automotive Forum 13 10-12-2004 03:36 PM
Look at my Custom M headrest Mod!! dknj23 3 Series & 4 Series 0 10-26-2003 10:17 AM
