E34 (1989 - 1995)
Difficult to start then misfires alot then is ok
Hi,
I have a 1989 535i SE which has an intermittent fault. Some times it is really difficult to start and when it does get started it misfires really badly but after driving for about 20 minutes to ½ an hour it sorts it's self out and drives fine. It doesn't do this every time. I was thinking it could be moisture getting into the ignition system either in the distributor cap or somewhere in the ECU. I've ordered new plugs, leads, distributor cap and rotor arm to see if that helps. Has anyone had similar problems, and if so, how did you cure them? Thanks |
that all may fix your problem... but check out these two sites and post back your results...
http://www.bimmer.info/forum/forumdisplay.php?f=10 http://www.bmwe34.net/E34main.htm |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| This Is The Official Hijack Thread... | Sabrina | Off-Topic | 146 | 05-21-2009 06:38 PM |
| ***help, Car Won't Start - Possible Engine Flood!!!*** | bmw_reloaded | E34 (1989 - 1995) | 13 | 07-24-2007 03:27 PM |
| Bimmer Ownership Phases... (Very very long) | FSelekler | General BMW | 31 | 02-08-2006 02:36 PM |
| Help! 325ix Won't start. | nolancumings | E30 (1982 - 1993) | 1 | 04-24-2005 03:21 PM |
| cold start clinking noise | sj-02-325Cic | 3 Series / 4 Series | 13 | 04-05-2002 10:02 PM |
