E46 M3 (2001-2006)
Old 10-19-2005, 09:38 PM
safetywork safetywork is offline
Mein Auto: '04 E46 M3 (6 sp)
Originally Posted by AJAX
This depends on the light in which the dealership looks upon these events...
I guess that would be true but my fellow weekend warriors haven't been turned down for brakes yet or for any of warrantee repairs for that matter.
Charles H.
'08 E60 550i (6MT, Sports Pkg, Comfort Access, Winter Pkg, Nav)
Old 10-19-2005, 10:31 PM
liuk3's Avatar
liuk3 liuk3 is offline
This side up.
Mein Auto: E46 M3, XL1200S, E39(RIP)
Originally Posted by safetywork
LOL.... You'll catch up to me in no time! I've got 41k (42k by Friday) and I got the car last April. If I wasn't traveling so much, I'd probably have closer to 50k miles.
Old 10-20-2005, 05:42 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Originally Posted by Moderato
If the dealer determines the car is used for track all of your warranty's will be void. I'm not sure if the maintenace program covers that either.
BALONEY.
I have had the dealer flush my brake fluid with Motul 600 RBF. They KNOW I track the car. I took it in for an alignment and gave the tech the specs I wanted, he siad, "Oh, a track alignment" and then did it. People have had the dealer not provide new pads after eating a set in 5 - 10K miles. They gave them the first set then said no more, but serious track people don't run OEM pads anyway. My dealer offered to INSTALL adjustable lower rear control arms on my car since they couldn't get the rear negative camber to the maximum spec.
One guy had his brake system warranty voided for running ATE Super Blue, but realize that Super Blue is NOT DOT approved, so he was running a non-street legal brake fluid. ANd that was PIA dealer.
Yes, Mitsubishi and a couple of other companies were voiding warranties over autocross and track use, but not BMW>
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 10-21-2005, 12:46 AM
Originally Posted by Pinecone
BALONEY.
Not to go off topic but could you share your alignment specs? Always good (for me anyways) to know how others are setting up their car. I've been experimenting with differing specs (on my third now) and I'm getting close.... but not quit there.
Thanks.
Charles H.
Old 10-21-2005, 03:23 AM
Pinecone's Avatar
M Mad
Last dealer alignment awas maximum negative camber (with the pins pulled) front and rear, minimum toe in in the front and about 1 degree toe in in the rear. This was within reasonably close to BMW ranges, but the edgess of teh ranges.
Now I run 2.7 degrees negative camber front, 0 toe in the front, 1/16 - 3/32" toe inin the rear, max nagative camber in the rear (about 1 degree is all I can get without adjustable low control arms). This is a street/track/autocross compromise. For more track and autoX I would run qabout 1/16" toe out in the front. And more negative camber.
All this is PRE-TC Kline suspension. That will give me more negative camber int h rear for track/autocorss and also convert the 0 toe to toe out, when the camber is reset for the track.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 10-22-2005, 04:40 AM
Chemical7's Avatar
Chemical7 Chemical7 is offline
Mein Auto: 04 M3
Holly molly!! You guys are putting a lot of miles on your M's, as it should be.
Unfortunately, I only live 1.5 miles from work so I now have 4,600 miles on it and took delivery 15 March 04.
04 M3 6sp: LSB/LSB > Moonroof > Power Seats w/Width Adjust > Xenons > HK > Highgloss Shadowline Trim > Power Rear Sunshade > PDC > Aluminum Interior Trim > Rear Spoiler Delete
Modds: 19" Black SSR Professor SP1's * ACS Style Carbon Fiber Lip * Kitamo CF Deck Spoiler * Carbon Fiber Grills * OEM LSB Leather Arm Rest * OEM LSB Leather Shift & E-Brake Boots * LSB Leather Trim Mats * Euro Tray * 35% Tint * Clear Reflectors * Titanium Headlight Trim & Foglight Rings *
Old 10-23-2005, 08:28 PM
Thanks for sharing. You must have camber plates to run 2.7 degrees negative camber. There is some adjustability with my KW V2 but max out at -1.8 degrees (front and rear). My front toe is slightly toe out with the rears slightly toe in.
Charles H.
Similar Threads
Bimmerfest Caravan Route, in case anyone missed it MarcusSanDiego General BMW Questions 19 05-02-2007 10:55 PM
ModBargains | January 2005 Specials Mike@Modbargains Site Sponsors & Bimmerfest Group Buys 10 06-10-2006 08:35 AM
Non Z but still BMW related... my new daily driver! bol E36/7 Z3 (1996-2002) 3 03-18-2005 10:37 PM
Why is the lease so high on an M3? spta97 1M & M2 11 08-31-2004 01:29 PM
What do you guys think about using an E34 M5 as a daily driver? TD 1M & M2 45 04-09-2003 08:45 AM
