05 530 brake squeal - Bimmerfest - BMW Forums
Old 11-08-2005, 12:53 PM
jking05 jking05 is offline
Mein Auto: 2005 530i
05 530 brake squeal
My 05 530 has 5k on it and when i slow down the brakes squeal really loud. It sounds like a damn taxi cab. They put degreaser on it so they said and it did nothing. Anybody else have this problem. Its embarassing to even slow down at a stop light.
Old 11-08-2005, 01:02 PM
stream's Avatar
stream stream is offline
Mein Auto: '05 545i
It's most likely caused by glazing of the brakes, typically caused by not-aggressive-enough braking. Get on the highway in the right lane with nobody behind you, and at 60 MPH brake--hard--to get down to 30 MPH, and repeat a few times. This will burn the glazing off your brakes, but it may return after a while if you're not an aggressive braker!
2005 545i - sold
Similar Threads
Brake Sensor ? ahspao E39 (1997 - 2003) 1 10-17-2005 11:45 AM
Rear Rotor Grinding Noise - Could it be the Parking Brake? MantisMan13 3 Series & 4 Series 9 11-09-2004 07:35 AM
Best dustless brake pads that do NOT squeal Dennis33 E36/7 Z3 (1996-2002) 14 02-12-2004 02:21 PM
New research to eliminate brake squeal electronically DZeckhausen Tire Rack's Tires, Wheels, Brakes & Suspension 7 10-22-2003 09:19 AM
Brake replacement help... Cal 3 Series & 4 Series 2 04-04-2003 12:39 PM
