E34 (1989 - 1995)
Old 11-01-2005, 07:27 PM
bmerritt bmerritt is offline
Mein Auto: 1995 540i
rough idle in the winter
My 1995 540i idles rough when the temperature dips below 60 degrees and the check engine lights comes on. If the temperature during the day rises above 70 degrees the check engine light goes out and the car idles fine. What is this problem and how do I fix it?
Old 11-03-2005, 02:23 PM
EJ EJ is offline
Mein Auto: 94 530i
Sounds like you have a vacuum leak. Do a search here and post if you have any questions. Several people there have just fixed the exast same problem.
Old 11-08-2005, 05:37 PM
SharkmanBMW SharkmanBMW is offline
On the HI-Way of Life
Mein Auto: '94 540i, '03 330Xi
http://www.bimmer.info/forum/forumdisplay.php?f=10
the best place for the e34 series information
Similar Threads
ZHP rough idle, 2005 ZHP Grunt66 E46 (1999 - 2006) 18 10-27-2005 07:11 AM
rough idle Boile E46 (1999 - 2006) 4 07-08-2005 08:39 PM
Software update for 4k rpm power drop and rough idle TLudwig E46 (1999 - 2006) 3 05-13-2005 04:32 PM
Rough idle and Check engine light??? dvs7310 3 Series / 4 Series 3 07-16-2004 08:48 PM
Which snow tires should I get? SizzlerMA Tire Rack's Tires, Wheels, Brakes & Suspension 25 01-30-2004 05:12 AM
