E34 (1989 - 1995)
Old 11-01-2005, 03:09 AM
seany1232001 seany1232001 is offline
Mein Auto: 89 BMW E34 2.0I
Central locks stuck in open position
Hi there , hope someone can help?
Central locks are stuck in the open position all doors.
Can't even push the knobs down by hand- even if i take the battery off.
tried reset procedure ect to no evail?
Has anyone else had this problem or know the fix?
This is an 88 2litre, I bought as a runabout but dont want to fork out too much money.
I am quite handy though - but electrics is another thing?
may thanks
Old 11-03-2005, 02:33 PM
EJ EJ is offline
Mein Auto: 94 530i
Bimmer5michael has messed around with these locks a lot. He might be able to help. Look for him over on roadfly.
Old 11-08-2005, 05:33 PM
SharkmanBMW SharkmanBMW is offline
On the HI-Way of Life
Mein Auto: '94 540i, '03 330Xi
http://www.bimmer.info/forum/forumdisplay.php?f=10
Old 11-09-2005, 07:30 AM
thaks sharkman but that lik takes me back to main forum???
Old 11-09-2005, 11:03 AM
cawag98 cawag98 is offline
Mein Auto: a cranky 535i from 89
opening locks when battery dead
Hi: I have an 89 535i. I also thought that my car was different, when several different attempts over different days at turning the darned key didn't open the door.
I think the instructions from the e34 page you cited are correct, you just have to keep wiggling and pressing the key to the side they indicate (I always attempt the driver door, but I think it works on the passenger door). When it finally wiggles the lock up, it doesn't feel very german or precise - in fact it feels a lot like a lock on an escort giving in to brute force!
By the way, my car was running the battery down overnight, which we only solved when we noticed the locks were getting hot. We opened the door and disconnected the heater unit switch and now the car is fine.
Old 11-10-2005, 01:24 PM
you need to SEARCH!!!
you will find tons of info.
If you turn key and they lock, then unlock, it is a wiring issue, likely in the trunk.
But you will find all the answeres, have a look
Similar Threads
convertible top stuck in the open position mouse E36 (1991 - 1999) 1 10-04-2005 07:18 PM
Friendly reminder (Manual Override Door Locks) PuppyDawg General BMW Questions 7 06-03-2005 05:11 PM
help flip window on coupe is stuck open! gokcer 3 Series & 4 Series 0 07-05-2004 11:26 AM
Drivers window came loose..stuck open sltahoe 3 Series & 4 Series 6 06-14-2003 12:22 PM
