E60 (2004 - 2010)
Old 10-31-2005, 04:47 PM
Torch Torch is offline
Mein Auto: 545i
Headlight question
OK...so I can't figure this one out. On my '05 545 I have what appear to be two Zenon headlights on each side (plus the fog lights). With low beams on, the outermost pair are on. With the high beams on, the outermost pair remain on. The inside pair, as near as I can tell, don't ever light up. The fogs work as advertised. I'm sure there is an easy explanation, but looking for help!
Old 10-31-2005, 05:17 PM
reb03's Avatar
reb03 reb03 is offline
Mein Auto: 2007 335i
We have bi-xenon lights so the two outermost lights are for both low and high beams. The lights inboard of that are for the DRLs or for flashing at other cars.
Old 11-01-2005, 03:53 AM
Mein Auto: 545i
Thanks for the info...
Is there a position on the switch that turns on the daytime running lights only or is that something that has to be programed in at the dealer?
Old 11-01-2005, 09:41 AM
BillP BillP is offline
Mein Auto: Cars
I believe you do it via iDrive.
Bill
'00 540iA/Sport, Anthracite/Black - Euro Delivery in Spring 2000
'06 Honda S2000, Black/Black (my go-kart) - GONE
'03 Z4 3.0 6-speed/Sport, Sterling Gray/Black - GONE
'71 2002 Green/Black - GONE
Old 11-01-2005, 10:41 AM
kscarrol kscarrol is online now
Mein Auto: 2011 E90 M3
Nope, here in the U.S. (all of North America in fact) it is set by the dealer. A number of states and Canada require them so BMW doesn't want us turning them off on our own... At least the way it used to for '04 and '05 models, maybe '06 has changed.
Old 11-02-2005, 12:06 PM
dfortier dfortier is offline
Mein Auto: 2008 750i
Daytime Running Lights
I have a 2006 525i I took delivery on this past Saturday. I noticed the same thing with the DRL's. My automatic lights came on in the garage -- as you would expect them to -- but did not go out in the bright sunlight, at least not until I arrived and turned the car off. The DRL's never came on .
I contacted my dealer and they took about 20 minutes to reprogram the DRL's and the Automatic Head Lights Now the DRL's come on, I can see the reflection on the back of cars in front of me, and the Automatic Headlights go out in bright sunlight.
Old 11-10-2005, 05:53 PM
bjf123 bjf123 is offline
Mein Auto: 1999 Z3, 2006 Boxster
I'm a little confused. Are you saying you want the DRLs to stay on regardless of how bright it is outside, and the headlights to only come on in low light / night situations? I've also got a 2006 525xi. I'd like the DRLs to not be on at all, but the headlights to come on automatically in low light or at night. Can that be done?
Golf is a relatively simple game, played by reasonably intelligent people, stupidly.
Drive a Roadster? CinZroadsters
Old 11-10-2005, 06:27 PM
Yes it can be done as long as Ohio doesn't require daytime running lights (DRL). If they don't, go to the dealer and have them deactivated. They are not required here in Louisiana so my dealer asked before delivery whether I wanted them on. If they are deactivaed, leave the headlight switch turned all the way to the left, or On (A) and that will leave the auto function active so that darkness triggers the lights.
Old 11-11-2005, 10:06 AM
Thanks. DRLs are not required in Ohio. I guess I'll be contacting my dealer.
Similar Threads
Xenon headlight question!!! drewmvshs 5 Series 1 06-09-2004 05:53 AM
Phillips VisionPlus headlight question hagenmi1 5 Series 17 01-10-2004 09:42 AM
Headlight Question Bavarian 3 Series / 4 Series 9 10-29-2002 02:11 PM
question on headlight bulbs asura0s9 General BMW 1 09-01-2002 04:57 AM
